loading
Talkbox MOD
ok so, after reviewing James Haskin's TALKBOX  he splits the feed from his guitar amp through a DPDT switch and he mounts it directly onto the guitar amp.... I was wondering how difficult would it be to make a stomp box feature for this?? with maybe a few LEDs to let you know what your running.. i posted this as a question but being new to the site i'm not sure how that worked so i posted here too...
1-10 of 18Next »
funkbass (author) 7 years ago
 ALRIGHT!!!!!!!! BREAKTHROUGH!!!! (powered by google/wikipedia) ok so if i have this right (no garuantees) but the the power supply i will use isnt in anyway connected to the speaker or the talkbox... its in essence 2 seperate circuts.. there should be like 8 connections 2 should be the coil and well it should look like this
                [A1]    [A2]                   these two go to the original speaker                                      [C1]   [C2]  these two should be the amp out (this is the armature)
                [B1]    [B2]   this is the out connection to the talkbox
            {coil}====={coil}
so when the coil is energized it atracts C1 and C2 (the armature) towards the connection of B1 and B2... ok so i got that the next thing is the LED
where do i attach that? I would have to attach some where between the coil and the switch which if i am not mistaken i need an DPST switch? right?
In all I'm thinking of using a 5v/1A  DPDT relay and i need a 5v/1A AC to DC adapter (something like the guitar pedals use where i can plug it in and out of the stompbox instead of just the wall) and the receptical for that an LED and the necesarry resistors for that (which i now know what to get thanks to ohms law!!)
**wow question about resistors**
1 Amp = 1000 mA
so in my division its       R = V / I     and my LED is 2v x  20mA
                   that means ohms law says 3v/0.02 (20mA) = 150 ohms
so i need to have 150 ohms of resistance in the
**I guess my main question after all of this rambling is do i hook up the LED and resistor on the negative side of the coil like so?
{Coil=====Coil}
[resistor]         |
   [LED]            |
 {POWER SUPPLY}
obviously with a switch between? is that correct?
.  Having the LED and resistor in series with the coil may work, but I'd connect it in parallel.
.  For an audio application, I'd use a 3-wire, shielded cable - one wire from PS to hot side of sw, one wire from coil side of sw to relay coil, one wire from PS negative to LED.
.  You might be able to go with: the resistor to the coil side of the switch and the LED, and the other side of the LED to the box (ground/-/the shield of the power cable).
funkbass (author)  NachoMahma7 years ago
 also I am trying to use as many spare parts as i can and keep this super cheap... if a relay says Form C (from what i understand this mean DPDT) 5v Single Coil does that mean that i do not have to meet any ampre requirments for the coil to throw the switch??? because i have a 5vDC/700mA power supply that i would love to use for this just to keep things simple... but all the relays i have found either say 5v/1A or they are 5v Single coil and they don't list a ampre requirement??
.  Form C just means that one or more SPDT switches are ganged together (xPDT)
.  The 1A rating is probably for the switch contacts, not the coil. Coils usually have a pretty high impedance/resistance.
.  I don't have a relay handy, but I don't remember any having the coil current on them. You should be able to get that info at the manufacturer's web site. Or, since you are using DC, measure the resistance of the coil and apply Ohm's Law.
. Don't forget a clamping diode across the coil.
 ok... I knew about your first point...
the second one needs me to see what my amps rating is...
the third one is ok...
but your fourth one about the crimping diode....WAY over my head
.  When you de-energize a coil, the collapsing magnetic field induces a reverse polarity voltage spike. A diode, installed "backwards" across the coil, will short out that spike.
.  Not difficult at all - just use longer wires to the switch. Make sure you use high-quality, shielded cable and follow grounding rules to minimize losses, distortion, and hum. Using shielded wire to the LED may be overkill, but I'd do it anyway.
 whats the difference in a switch and a relay?
.  A relay is an electrically operated switch
 i'm sorry wasnt thinking when i posted that... but the thing is.. i want to choose weather or not to go through the speakers or the talkbox i am building it sounds like the relay will be set so when i turn on the amp it automatically goes to the talkbox... and GMOON.. i am using a solid state peavey rage no tubes for me!! thanks bra
1-10 of 18Next »
