loading
The KLS V.2 *Updated*
Can I get a W00T for summer???
Now that summer is here I have had a bit of extra time to dedicate to my gun building, and I have completed my Semi Auto.  The Kinetic Last Stand is a small, compact semi auto rifle that utilizes 4-shot low cap removable mags and has a firing mechanism that originated from Louis XIV's semi auto, just a bit more complex.  My idea of this has been around since christmas when I posted pictures of my first attempt of this gun, however It required too much energy to pull the trigger that was necessary, and so I created the V.2, which uses a simpler, more efficient trigger that allows you to utilize the energy of 2 #64's with little effort.  The only downside is the mag capacity, which can be improved by a about 1.5 for every half moon connector that the mag, and in turn, stock, is extended.
Thats about it...the video will demonstrate just how impressive this gun is.
Maxed out means the maximum amount of power I would use for a war for the sake of keeping a high rate of fire.
Let me know what you think!
Picture of The KLS V.2 *Updated*
1-10 of 51Next »
Are you going to post it!?!?! I have 14 days left until school.
Seleziona6 years ago
That's Crazy! Good work
Kinetic (author)  Seleziona6 years ago
Thanks! You have anything new you're working on?
Not at the moment, no. Don't have any ideas, and I don't want to make another replica.
Hmmm...I designed a sling repeater a little while back but I cant build 3-layered guns for my life. Maybe you can give it a try? It has a 3 layered body with a 5 layered mag/slide. When the slide is pulled back, the bullets in it are brought above an opening and one slides in. When the slide is released, a pusher loads the bullet into the barrel. The slide also pulls back the sling band which latches on a ratchet. Let me know if you think you can do anything with it.
It's quite complicated if I must say. I would try to make it but I can't quite understand it yet. Would you mind making another picture of the slide pulled back and a bullet loaded?
Yeah I'll work on another diagram for you.
Thank you very much!
Here you go. Sorry for the wait.
Ahh! I get it now! Thank you so much :D
1-10 of 51Next »
