The m2 carbine...
The m1 carbine was good... but it was not nearly as much as I could give... cons of the v1: 1: friction 2:slow loading 3:3 layer flimsy 4:inaccurate pros of the m2: 1:5 layer thick crosshairing body for max str 2:new bullet for extreme accuracy and shortened loading time 3:new realistic stock 4:mag holds 2 extra. has a realese you pull to get a bullet 5:slightly modeed trigger mec 6: trigger gaurd 7:better looks that the m1 carbine v1 8:better handle than the old one cons of the m2: 1:uses way more pieces than the m1 carbine v1. tell me if you want my third rifle on this site!
Picture of The m2 carbine...
1-10 of 12Next »
The Jamalam9 years ago
please post! Also, make an M3, M4, M5, and M16 :D
benfoxg (author)  The Jamalam9 years ago
lol i'll try. I've got all the pics taken today for the insructions, it should be up today =) (p.s. yesterday i got a range of 130 feet)
wowza!
it's posted now
lol
Trauts9 years ago
Not a very good picture so I can't really say much, it does look a lot better. You said a Con was "inaccurate" and then said a Pro was "new bullet for extreme accuracy and shortened loading lime" which doesnt make much sence cause they contredict each other.
benfoxg (author)  Trauts9 years ago
no. the first list of cons is the v1. the 2nd list is the pros of the m2. the third is the cons of the m2.
Trauts benfoxg9 years ago
OK gotcha. It would probably be better if you changed the sentences around cause it's kinda tricky.
done!
Cool. Are you posting an instructable of this?
1-10 of 12Next »
