Timed Shocker, or Shocker w/ a Timer
I was wondering if anyone knows how to build a shocker hooked up to a timer? Or at least how to hook up a timer to a shocker? If anyone can show me how to hook a good, strong shocker to an electronic timer, i'd be grateful. I already have a timer and i can post pics of it's insides if anyone wants a look, it's the one i plan to use. I was hoping to rig it up to the world's smallest shocker. Thanks in advance.
1-10 of 11Next »
Kiteman8 years ago
If the timer is electronic, and sounds a buzzer, replace the buzzer with a wire from the shocker to the shockee, with the other wire going there directly. If it's a mechanical timer, go old-school and use the turning dial to close a switch.
the clock buzzer output won't keep 300+ V in open circuit. it goes directly to a chip that is designed for 1.5 V. itll just break down
So replace the buzzer with a relay that will survive the voltage.
if the buzzer output can supply enough for the relay to work + if the relay will react to 1 KHZ pulsed dc otherwise a transistor is required
Of course - it was just a vague idea in response to a fairly vague request.
lemonie8 years ago
I quite like the idea of a clockwork timer - if you can find a wind-up egg timer, and connect it to a disposable camera-flash? Or the classic alarm clock. L
Kiteman lemonie8 years ago
It's a classic of the home-made bomber - a wire on each hand of the clock, connected to the detonator - when the hands meet...
lemonie Kiteman8 years ago
Yep, but which wire do you cut first? L
bumpus lemonie8 years ago
Oooh! The red one. :P
lemonie bumpus8 years ago
I was thinking 'blue' - maybe I'll leave these things alone in future... L
1-10 of 11Next »
