loading
USB Port
I posed a problem regarding my TV Tuner card for which i got a very nice solution and my problem is solved. I have Two more problems. Yesterday i got a new detachable Hard disk with a capacity of 160 GB I have partitioned into two. Say D rive and H drive. Whenever i plug in my divice one of the USB port in the computer, i get a message lke this " Hi-SPEED USB Device attached to non Hi SPEED Hub. The recommendation is The USB main Storage Device will function at reduce speed. You must add a High SPEED USB Controller to the Computer to obtain maximum performance, Kindly let me know whether it is a software problem or a new hardware has to be installed.. Further when i referred to the CD i got along with the Motherboard, it says USB ports with a speed 2.01 will support if i have SP1 and above. I have already having SP2. Kindly advice me. Secondly I am not able to open D Drive. When i attempt, I get a message saying that it is not it is not accessible. How to open this d drive How can i format the the new hard disk. I have no file or folder in the new hard disk. Regards, Bala TV
NachoMahma9 years ago
> Is there any good software to find out the duplicate files and delete them.
. Try SourceForge
> I found some software and deleted some registry files with the result I had to format the software.
. RegSeeker works well for me.
> " Hi-SPEED USB Device attached to non Hi SPEED Hub. The recommendation is ..." > "The USB main Storage Device will function at reduce speed. You must add a High SPEED USB Controller to the Computer to obtain maximum performance, ..." . All this means is that you have older USB hardware in your computer. Everything should work, it'll just be a little slower than if you buy a new (USB 2) card. . . No idea about the drive not opening problem.
balatv44 (author)  NachoMahma9 years ago
Thanks for the quick reply. I will certainly change the USB 2 card tomorrow and inform the results. As you have stated, the speed is little slow. I have formatted the D Drive and it is working well.I selected the drive and right clicked the mouse and formatted. I am very hapy you are all with me to educate and sort out my problems though i am an uneducted so far as the computer is converned. Slowly I am gaining the confidence to tackle any problems with the computer since i have proudly say that you are all there with me and your able supprot i never forget. Kindly continue your good and valuable service. I am in the habit of downloading somany software regarding video editing etc. With the results my hard disk gets filled. sometime i duplicate the software also. Is there any good software to find out the duplicate files and delete them. I found some software and deleted some registry files with the result I had to format the software. How can i arrest this problem. with regards. Bala TV
