USB powered computer fan for Xbox360
I'm building a Gaming computer desk and have built a place for my xbox360 to go under my monitor which will require fans to keep it xtra cool to avoid the dreaded red rings of death. I would love to be able to get power somehow from my 360 i have a 120mm comp fan and tons of extra USB cables. I seen a post where someone used a batt operated fan and connected it to a USB. Will the same concept work? Do i risk damage to my 360? Thanx! Ray
CyborgRay (author) 8 years ago
AH thanx much Albylovesscience! I'm on my third 360 sense launch ( one red ring due to heat and one damaged cd drive due to being put in the vertical position) so im taking every precaution i can. Thnx again for the links.
no problem
if it helps at all
http://mr-ives.blogspot.com/2007/10/diy-xbox-360-cooling.html
http://xbox.joystiq.com/2006/03/17/usb-fan-for-diy-360-cooling/
ohh and don't worry in game-stop they have the 360 inside a Plexiglas kiosk about the same size as the box the 360 comes in the kiosk has about eight holes drilled in the box about the same circumference as a pencil so don't worry too much about ventilation
