3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Use a 3d printer for etching PCBs?
Here's an idea - would it be possible to use a 3D printer to lay out the etch resist on a PCB?  It would likely only need to print a single layer.  Of course you'd need to use a material that would resist the ferric chloride but could also be removed without leaving a residue.
Thoughts???
10 comments
Jan 30, 2012. 10:41 AMMachine says:
You should be able to use a 3D printer to lay down ink resist on a PCB. You only need one layer so that is only one pass to complete all the tracks.
You'd need to find a way to deliver the ink resist through some kind of delivery nozzle (ink is available in bottles), pen (ink resist pens are available).
An old plotter will draw PCB lines. If you can change the pen for another that holds an ink resist pen then you can draw your PCB layout direct to copper.
All you do then is etch the board in ferric chloride, clean, drill and solder up.
Nov 30, 2011. 6:56 AMGoodhart says:
I am a bit confused as to why this would be needed or advantageous also. Since most PCB's are printed, quite literally, in pretty much 2 dimensions, the only time I can see an advantage would be if you were printing on a 3-d object, like a cube.
Nov 30, 2011. 12:07 PMGoodhart says:
Ok, I suppose that doesn't sound too difficult, if the "ink" can be made the proper viscosity, and yet not need special "treatment" once laid down...
Nov 30, 2011. 7:56 AMledartist says:
How about milling the PCB with a CNC tool? I've seen it work at MakerFair.
I've got myself a 3D printer recently, and have been planning to add a milling head, so that I can mill PCBs. No etching. Just mill and done.
Then if I can also add a drill head...
Aki
Nov 30, 2011. 4:51 AMsteveastrouk says:
Make yourself a UV exposure unit, and do it the proper way ;-)
It gives much better results than TT or Inkjet methods.
Steve
Nov 29, 2011. 9:06 AMKiteman says:
Why a 3d printer?
That is already possible with both laser printers and inkjet printers.
Having said that, I'd think that you could print a single layer of ABS onto the board as a resist, no problem, and then peel the plastic layer off afterwards.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
