Username breaks some links
I have discovered that our username breaks certain links on the site although it presumably passed input validation when we set it up. First locate any use of the username such as on the Instructable here: https://www.instructables.com/id/A-Quick-Laser-Cut-Sailing-Trophy/
The link has been encoded as
https://www.instructables.com/member/Sean%2BJames/
which is not being processed correctly resulting in the 400 error
This has been tested on Firefox on Mac, Chrome on Mac, Firefox on Windows.  I know it is not a browser problem but I thought I would do a bit of testing.
Picture of Username breaks some links
kelseymh5 years ago
The plus character is special -- it is how the HTTP protocol encodes a space (blank) in a URL. The simplest, and most likely to be successful, solution is for you to change your username to "Sean_James" or "Sean-James". Don't use any of "#", "&", "+", "/" special characters.
Sean+James (author)  kelseymh5 years ago
They have encoded the "+" correctly as &2B. The problem is that somewhere within the web tier they are not processing the URI correctly almost certainly as part of SQL injection protection. I have no real issue with changing the userid but there should be validation to catch this, or better back end validation.
Ah, ha! The "%xx" encoding is not an "escape sequence". It does not replace the meaning of special characters.
For example, the two (partial) URLs /~kelsey/index.html and /%7Ekelsey/index.html are required by the RFC-1866 spec to refer to exactly the same files on the server.
In your case, both Sean+James and Sean%2BHames both refer to the same path on the I'bles server, namely, a file or directory named "Sean James" with a space in the middle of the filename.
The bottom line is that you just cannot use any of the "reserved characters" as part of a username: no spaces, no "+", "#", "?", "/", etc.
Kiteman5 years ago
Send an email to service@instructables.com and ask them to change it to something else (maybe "Sean_and_James"?).
Jayefuu5 years ago
That's really annoying, I want to look at your profile!
