loading
Using a computer fan to lift a solar cell
Hi!
my boss told me to come up with a cheap replacement for a vacuum pump and since it's needed to lift only two solar cells at a time, I thought a fan could be used to create negative pressure. The cells are really light, but since I suck at physics/fluid dynamics, I thought I'd ask if I'm way off base and if I am, is there any solution to this problem.
I attached a picture of the current state of the idea.
Picture of Using a computer fan to lift a solar cell
Kiteman5 years ago
I strongly doubt that a PC cooling fan could do the job.
I would recommend, instead, using an actual vacuum - a hand-held vacuum-cleaner is fairly cheap, plus it is designed to pull significant pressure-differences, and it should be reasonably easy to add a flexible hose to the business end, and to replace the rechargeable battery with a wall-wart.
TashaDax (author)  Kiteman5 years ago
*facepalm*
I can't believe I hadn't thought of a hand vacuum... Thanks.
Not a problem.
