loading
Volts from an USB cable
I need to know how many volts a usb cable provides from a laptop. I couldnt find any information on google and I know that someone here has to know.
1-10 of 12Next »
5volts 500mA
thats only if the chip you power requests power from the port through the data cables. otherwise, you only get 100 ma
The two main voltages in a computer are 12V and 5V. In the case of a USB port it is 5V. Perfect for most projects.
tech-king9 years ago
hang on a sec. dont start yet because: unrequested, you can only get 100ma from a usb port. requested, you can get 500ma. exceed the limits, and either the main board fries or the port gets shutdown. also, you will find a bare wire (sheild) and a string (feed cord)
wingman2469 years ago
its like this...
not all cables are shielded... Which is handy for dumb projects, any constant data stream ones and the like of camera ones tend to be though.
The red and black wires are a 5 volt line, the other two are data cables, red - positive, black - negative, green - data, I cant remember the other colour It might be blue, it's data aswell.
its white
Thanks I was having a durr moment...
it also depends on the cable, standard, yes, but really cheap ones don't follow any code.
1-10 of 12Next »
