Wall of PC Case Fans?
Hello guys, sorry if this is the wrong section but, I was thinking of making a DIY fan out of PC case fans to keep myself cool in the summer. I've tried a number of fans in the past, but they don't seems to be very good. I usually put them right next to an open window to draw cold air in. I was thinking of making some kind of rig like in the video below, only without the bitcoin mining computer. I got the idea from this video and from when I was messing around with the fans in my own PC. I was chancing the speed of the fan for the PCI cards and noticed that it could get really cold if ramped up a bit.
I was thinking of using 9 identical 120mm or 140mm fans, preferably ones that can be used with a fan controller. Here is a few of the things I need help with.
How will I power the whole thing? What kind of cabled will I need?
Could I use a fan controller to power all 9 fans? Can I even hook up 9 fans to a fan controller? Maybe I could use 2 fan controllers or something?
What brand of fans should I use?
How will I attach the fans together? Cable ties like in the video? Maybe I could make a makeshift wooden stand to hold them upright.
For power just use an old PC PSU.
No cables needed. You can cut the connectors off the fans and 1 or 2 of the 12V wires of the PC PSU and solder it all together. You'll likely need to add wire to the fans to make it work. Using a nice terminal black will help to keep the transistion between the fans the the power cables from the PSU more organized.
http://www.newegg.com/Product/Product.aspx?Item=9S...
Depends on the fan controller you use. There are 5.25" bay controllers that will control multiple fans. You may find you'll need a couple of them to control all 9. Or just connect the fans directly tot eh PSU. Chances are you'll keep them running full speed unless noise becomes a problem.
Connect them the best way you can. Zip ties are a great option then have them attached to a wooden frame so it's nice and rigid.
