Wanted: A contraption to punch two parallel holes in a pumpkin (see pictures)
I really could use some help with this project.
I live in Williams Bay, Wisconsin and the Williams Bay Recreation Department and the Williams Bay Business Association hold a pumpkin race around Halloween. The pumpkins have to have two parallel axles, four wheels. I attached some pictures of what we have been using, but frankly it doesn't work.
The contraption we have is a piece of wood, 4x4, with two holes drilled into it. We have two long screwdrivers that go through the holes. Pumpkin pushed up against the wood and the scewdrivers shoved through. We also took off the handle of a scewdriver and inserted it into a drill and that seems to work great. However, the holes were never small enough and the screwdriver can move around inside, which defeats the whole purpose. Also there are only two holes and that limites the size of pumpkin that can be used.
I like the basic idea of this Pumpkin Punch. We just didn't have the right tools or know-how to do it right.
The axles have to be parallel or the pumpkin will not go straight.
We, the Rec Department, use 5/16 threaded rod and six inch rubber wheels. The morning of the race, volunteers help attach the wheels and axles for the children, which is why we need this contraption.
I would also like an Instructable made on how to build a pumpkin racer so that the Rec Department can direct people to it for questions.
Check out www.wbhalloween.com for some more information on our event.
I hope there is someone that can help. The next Pumpkin Race is set for October 30, 2010.
Thanks
JUNE 2013 Build Night - 3D Printing with 123D & Tinkercad
Instructables Build Night w/ Bare Conductive @ Noisebridge
Embed a 3D viewer in your Instructable
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Got contest ideas? Want to help HQ staff?
Large Instructables Robot head made out of driftwood, check it out!
Call for pre-made parts!
The Instructables Green Design Contest is starting on Earth Day!
Visit Our Store »
Go Pro Today »
Get two pieces of wood, say 2 x 2, mount them in a drill press, and drill two holes through them, the distance apart of your axles, and holes the diameter of your axles..
Get a board, say 12" wide, and with two parallel sides, and mount one of the pieces of wood along one side, and the other along the parallel one. Put two pieces of rod, the size of your axles through the holes to set them perfectly parallel.
Make up a simple stand to hold the board at a little more than the height of the pumpkin,
Using sand, make a pile that you can sit the pumpkin "upside down" on, and at such a height you can drill through your jig and the pumpkin with a nice long length of axle rod.
Get someone to hold the pumpkin firmly while you drill.
. If you want to drill, get a long (as long as pumpkins are wide) auger bit.
