Washing Machine drain water disposal
21
comments
Add Comment
This is a forum thread, asking a sensible question.
What you're doing - hunting down an old thread to try and make some sort of revenge-point - is quite against the spirit of the site and breaks the "be nice" policy clearly stated when you reply to any post or comment.
You're only new to the site, so we'll cut you some slack. Just be warned - neither spam nor trolls are tolerated here.
Then realises it means I spend more time roaming the forums than the site's owner...
Examples of gray water sources may include, but are not necessarily limited to the following:
• Discharge from dishwashers or washing machines;
• Overflows from toilet bowls with some urine (no feces)
• Sump pump failures;
• Seepage due to hydrostatic pressure;
• Chilled and condensate water; and
• Fire Protection Sprinkler Water.
Gray water may contain chemicals, biocontaminants (fungal, bacterial, viral algae) and other forms of contamination including physical hazards.
Time and temperature aggravate category 2 water contamination levels significantly. Gray water in flooded structures that remains untreated for longer than 48 hours may change to category 3 - black water.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
