What kind of battery do i need for my rov?
What kind of battery do i need for my rov? I'm in the middle of my rov project, i have five thrusters that take 60 volts total, 12 volts each and i don't no what type of battery to get like a car, atv, boat, etc....?
NachoMahma8 years ago
. How many amps do the motors pull? . How many motors will be running at one time? . What else on the ROV needs electrical power and how much? . Any volume or weight limitations? . How long between recharges?
Percise (author)  NachoMahma8 years ago
-Not sure how many amps, but the thrusters take 12volts each -Two or three motors will run at a time -The cam and lights, I'm using two 6v batteries -There's no weight limitations, the batteries for the thrusters will not be installed in the rov, there's not enough room -I don't no what u mean between charges Thanks for responding
. An automotive or marine battery should work.
I'll try that, thanks for helping.
Sandisk1duo8 years ago
if it is less then 1.5 ft in length, get a Li-ion or Li-poly battery if you need to power a full-sized submarine, go with a couple atv batteries can you connect the motors in parallel? it should save you some money, since you'll need less volts, more amps
