What tools do I need?
Hi, I recently moved out and have bought a new home that will require some renovations (I have some experience). However, I feel I will need to purchase a few tools, what are some tools that all DIYers should own. I have:
Power drill
Circular saw
Jig saw
Reciprocating saw
Hack saw
Hammer
Wrenches
other small tools
What are some other tools I should purchase? I'm going to be doing some basic construction, drywall work, laying wood flooring and quite a bit of finishing work... maybe roof work and electrical down the road? Any help is greatly appreciated
Power drill
Circular saw
Jig saw
Reciprocating saw
Hack saw
Hammer
Wrenches
other small tools
Lomography Konstructor - World's First 35mm DIY SLR
Office Warfare Book on Sale Now
List of Upcoming Contests (updated 6/6)
Spanish translations of Instructables / Instructables traducidos al Espanol
JULY 2013 Build Night with SUGRU
High-current, electronic sword-fighting, fancy drink pouring, and more @ Makers Local 256 Build Night!
New Instructables Books for 2013
Souped Up: Projects to Make Everything Better [Book]
Backyard Rockets Book on Sale Now
Visit Our Store »
Go Pro Today »
Tool chests are never sized right and all of those blow molded cases that come with the tools are useless once you get the tool out and attach all the accessories.
You will be constantly adding tools and getting giant stackable tubs or a whole bunch of 5 gallon bucket/used paint-drywall mud containers will serve you well to organize stuff.
Get a nice LED or fluorescent work light. Get a miter/chop saw with a stand, working close to the floor is no fun. Heavy duty extention cord with multitap at end.
Get a set of folding sawhorses.
I have a nice "gorilla type" extention ladder, they are really stable and collapse into a small frame, a nice work platform ladder.
Get a good shop vac.
Get a kreg pocket hole jig. You will find pocket hole screws are the perfect solution for building a lot of stuff and securing new studs or supports in places you ordinarily can go in with other methods. A good cordless drill and impact driver 12v lithium ion. You gotta check out how much better an impact driver does screws. Of course, a corded power drill is still necessary for those drill in masonary tasks.
I have electric versions of carpet staplers, brad nailers but I think air compressor tools is a better way to go.
Of course you need all the appropriate specialized tools for laminate floor work, tile work, carpet, and a whole bunch of stuff that you will need for plumbing and electrical work.
The list is endless and just gets bigger as you learn more. Good luck.
A few clarifying questions:
1) If I have a cordless drill, should I get an impact driver, or is it redundant?
2) If I remember, there are 12v, 14.4v and 18v cordless drills what do you personally recommend? Is it worth getting a set that also has a cordless circular saw?
3) How big of an air compressor should i purchase (gallon-wise)
hahahhahhaha or muwahhhahahahhahaha
to answer your questions:
Usually when drilling pilot holes and then screwing in the screw, you need to change bits out of the drill/driver. The flip drill/driver bit things and other contraptions don't work as well as having a dedicated drill chucked up with the right bit and a driver, especially if you need to do multiple screws/screwholes. The impact driver uses a rapid hammering technology to provide tremendous torque, so screws sink in like butter in hardwoods like oak.I find you have better control on the driving too.
Although Li-ion battery powered stuff is more expensive, it pays for itself with tool size/weight reduction, keeps a charge longer and provides more power. I like the Milwaukee 12v line of cordless tools since they have a metal chuck on the drill and the compact size is handy for the usual fixer up tasks that pop up. 18v is nice but gets more cumbersome to use for extended periods because of the increase weight. I prefer my 12v Milwaukee over my older 18v Ni-Cd set of Craftsman cordless tools. I never really used that small circular saw. May be handy for laminates or quick tasks, which I use my bigger jigsaw. I have a dremel multi-tool for those odd cutting tasks - crack a nut under the sink or trim off a piece of wood that you can't get to with a regular saw.
The size of the compressor depends on if you need it "portable" and what you are going to hook up to it. Note that spray guns and garage type tools (impact wrenches/sanders)need a bigger capacity to drive them. Contractors usually go with the 6-10 gallon pancake or double long tank versions for your nailers.
And if you are doing a lot of trim work, having a tablesaw and a collection of routers makes life a lot easier and fancier. Good luck.
