Who wants to test a new GM Script?
I've been working on this new Greasemonkey script that, IMO, is a lot better than the others.
It allows you to rate comments. Your ratings aren't for your own benefit alone: they're stored on a server where they are mashed together with everyone else's to create a full-blown rating system!
And, I'm using Google App Engine as a backend, so there won't be any server downtime!
For this, you actually have to do a little sign-up procedure. Go here, & put in your username. You'll then have to post a comment*, and then you can get the script. This makes sure that one user can't cheat the system by having 100 accounts.
From there, its pretty easy to use. Next to the username, 5 pseudo-boxes will appear. Use them as follows:
[!] - This comment answered the question in the topic (use sparingly)[+] - Positive vote[-] - Negative vote[x] - Remove your vote[?] - Help
If you run across any bugs, or have any suggestions, please let me know. I'll be glad to hear them!
From there, if I do fix a bug, here's the best part: you usually don't have to update anything! It will automagically use the newer version. In the future, I may require you to manually update, but there is a notifier in place, and yet it is very unlikely that it will be needed.
87 comments
Oct 15, 2008. 7:29 PMbumpus says:
I don't like the new script.... The stars are off the page... :(
Oct 15, 2008. 7:58 PMNachoMahma says:
. Same here. I only see three stars on some posts. . Disabled all other scripts and it still happens.
Oct 13, 2008. 11:22 AMDerin says:
how do i add the code into gm
Oct 14, 2008. 8:12 AMDerin says:
it was probably because i looked at it when i didnt use gm,it works now
Sep 15, 2008. 2:42 AMll.13 says:
It changes comment text opacity. o.0
Sep 15, 2008. 12:49 PMll.13 says:
mm, no, it makes it hard to read, on my laptop screen. :) so I hate it with a vengeance. :D
Aug 20, 2008. 1:13 PMraider2 says:
pls give the script
Jun 9, 2008. 5:17 AMxACIDITYx says:
Wow, Dude! This is freaking awesome!
Jul 19, 2008. 3:27 PMV-Man737 says:
Heck. Yes. Please. _
Jul 20, 2008. 8:35 PMV-Man737 says:
Take all the time you need, this is a 1337 feature and deserves the careful programming of an awesome scripter such as yourself.
Jun 10, 2008. 5:09 AMxACIDITYx says:
Uh-oh. I just upgraded and it wouldn't let me post comments. When I disabled Greasemonkey and reloaded the page it let me.
Oct 13, 2008. 11:23 AMDerin says:
test
no it works
Jun 10, 2008. 8:21 AMwhatsisface says:
Yep, same problem here. I can't post comments with GM enabled.
Jun 10, 2008. 9:32 AMxACIDITYx says:
Oh, I can post comments with most Gm scripts. But with this one it won't let me post comments. I can flag comments, but not reply or add comment. Hmm...
Jun 10, 2008. 10:22 AMwhatsisface says:
Yeah, I meant since I upgraded the script.
Jun 10, 2008. 11:08 AMxACIDITYx says:
yeah, me too. Now, I have to disable the script. *sigh* Nice job, Zachninme. You totally dropped the ball. Actually, It was a pretty cool script... until I couldn't post.
Jun 10, 2008. 11:54 AMwhatsisface says:
(removed by author or community request)
Jun 10, 2008. 12:06 PMxACIDITYx says:
Erm... That's what the <sarcasm> tags were for.
He did do a good job.
Jun 11, 2008. 5:15 AMxACIDITYx says:
M'Kay.
Jul 9, 2008. 2:07 PMNachoMahma says:
. The voting buttons don't show up for the top reply to a topic. :(
Jul 19, 2008. 3:21 PMV-Man737 says:
I find I am able to rate my own posts made prior to installing the script (or perhaps the significant factor is "before installing Greasemonkey").
Jul 19, 2008. 3:22 PMV-Man737 says:
LOL! Scratch that. I went to click on the + and my name blinked and the tags disappeared. Cute.
Jul 9, 2008. 4:01 PMNachoMahma says:
. hmmmm
  • Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9) Gecko/2008052906 Firefox/3.0
  • WinXP Pro SP3
. I have a few other GM scripts running. I'll see if disabling them helps.
Jul 9, 2008. 9:24 PMNachoMahma says:
. Check your dir on my FTP site.
Jul 19, 2008. 1:51 PMV-Man737 says:
I've done it! I have the script. A bunch of text. Now what am I supposed to do with the text? I am under the impression that I should plug it into GM somehow, but 1) the instructions for installing GM are muddy and vague and 2) I have Firefox 3. Am I on the right track, at least? And what is missing in those lifehacker instructions?? Agh!
Jul 19, 2008. 2:00 PMNachoMahma says:
. If you get a bunch of text, you don't have GM properly installed. I'd try uninstalling and then re-installing.
Jul 19, 2008. 2:57 PMV-Man737 says:
lol... I should have just come out and said it... I don't have GM in the first place. I think my main problem is that the lifehacker instructions are a bit assuming. I enter a couple of boolean names into my Firefox Config list, and suddenly I have GM?
Jul 19, 2008. 3:20 PMV-Man737 says:
After a quick trip to the Mozilla Greasemonkey page, I figured out you simply ask Firefox to install its own plugin... Lawl. The script looks awesome! I'm excited.
Jul 11, 2008. 9:22 AMxACIDITYx says:
It works like a charm!
By far my favorite GM script, minus the block Kn* one because I can block users who annoy me =p
Jul 8, 2008. 1:59 PMwhatsisface says:
Fancy compiling it as well? It'll make it a bit more accessible.
Jul 10, 2008. 12:06 PMwhatsisface says:
Good point, they're all a bit different, no?
Jul 11, 2008. 8:34 AMwhatsisface says:
I have. The effects are cool, if a bit laggy.
Jul 8, 2008. 11:49 AMAar000n3y says:
I did it and nothing happened...
Jul 9, 2008. 3:27 PMLithium Rain says:
LOL!
Jul 9, 2008. 3:50 PMLithium Rain says:
I dunno, "Were you the one trying to sign up as "Rooon"? " just tickled me somehow. :) I'm trying, greasemonkey isn't taking...
Jul 9, 2008. 8:47 PMLithium Rain says:
I don't think so, I think it's more of a matter of me being dumb.
Jul 9, 2008. 9:19 PMNachoMahma says:
. Commonly called Loose Nut Behind The Keyboard Syndrome. . If you're having problems installing GM, let us know. If I can install it, anyone can.
Jul 8, 2008. 1:40 PMAar000n3y says:
Oh, that makes more sense I've got it working now. You should make an instructable for adding this feature to instructables to spread it around more.
Jul 8, 2008. 8:13 PMGorillazMiko says:
Hmm, the GorillazMiko made me think of something else...
Jul 8, 2008. 11:45 AMnagutron says:
100% awesome. I just blogged this, here: http://mindtangle.net/2008/07/08/now-thats-diy/
Jul 8, 2008. 11:47 AMfungus amungus says:
It is cool. I just got it to work with some help from Zach.
Jul 2, 2008. 11:50 AMxACIDITYx says:
I like it! It's the best GM script I have... second only to the KNEX skript.
Jul 2, 2008. 9:46 AMxACIDITYx says:
TEST!
It works now!
Jun 30, 2008. 5:51 PMKentsOkay says:
Hey how do we run GM scripts again?
Jul 2, 2008. 9:44 AMxACIDITYx says:
Is it working now?
Jun 30, 2008. 6:17 PMKentsOkay says:
Ahh ok...
Jul 1, 2008. 9:33 PMNachoMahma says:
. Whatever works best for the programmer.
Jun 10, 2008. 5:50 PMLabot2001 says:
Automagically is my new favorite word. I think I'm going to get Greasemonkey now.... or should I wait for Firefox 3?
Jun 10, 2008. 8:10 PMNachoMahma says:
. Go for it!
. I use Pagerization! (autoloads next page of Google search results as you scroll), Instructables Forum Left-align (self-explanatory), Instructables without knex! (another one of Zach's), and this one (when I'm not commenting heehee).
. Lots of very useful scripts listed on the GM web site.
Jun 9, 2008. 12:11 PMwhatsisface says:
Sweet, I'm famous!
As a side note, this has been working fine for me so far, although it has some issues displaying when the *spammy* comments get too far right.
I'm using 3 RC 1, and it works perfectly under Nightly Tester Tools.
Jun 9, 2008. 1:03 PMwhatsisface says:
That, plus when I view topics such as http://www.instructables.com/community/Average-age-of-instructablites-How-old-are-you/, the buttons either refuse to appear or take way too long to load.
Jun 9, 2008. 1:15 PMNachoMahma says:
. I think that's related to the number of replies. I have the same problem with all topics that have a lot of replies.
Jun 8, 2008. 7:54 PMNachoMahma says:
. I thought you were too busy hacking accounts to have time to do something like this. <snicker>
. Just kidding, folks. For those of you who are nervous about installing scripts from the 'Net, Zach rates very high on my trust-o-meter. I've run several of his scripts over the past few months with no problems (maybe something displayed in the wrong place, but nothing that did any harm or crashed anything) and I really like his No K'n* script (fairly easy to set up to block more than k'n*, if you want). I've been using his rating script for a few days with no problems. It seems to slow page load by just a little bit (I haven't timed it, but it seems like less than one second), but most scripts do that.
. I'm not sure what he's doing, but, in theory, he will be able to track which account rates what and possibly your IP. I don't think he will misuse the info (or exactly what he might be gathering or doing with it), but be aware of the (IMNSHO, slight) risk as you decide to download and participate. I trust him and don't think it's a big deal, but thought I should mention it.
Jun 9, 2008. 11:58 AMll.13 says:
Even better, I think I remember Zach being an intern at Instructables? xD -
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
