Windows on a psp
Hello,ever heard of bochs? Erm...bochs for psp? Well,It sucks instead you DOSbox because Dosbox runs approx 3 times faster than bochs. Dosbox starts in approx 10 seconds Boots windows 3.1 is about 10 seconds Boots windows 95 in about 1 minute,not 10 minutes I have a few scripts that start it they are: osrun.bat (asks the user weather to start win 95 or win3.1) 95run.bat (boots windows 95) 31run.bat (starts windows3.1) Should i make an Instructable for this? you know..setting it up..making the images and whatever FAQ: Q:y u put windos95 Y NOT VISTA???!!!111 A:because a psp does not have a 1.5GHz duo processor and 1GB+ of ram Q:what other oses can it run? A:You can run the following: dos(comes in dosbox) OS/2 Warp(has not been tested but theoretically it should work) Windows 1.0-3.11(windows 3.1 has been tested and others should work) windows 95(tested and works perfectly) windows 98(ive heard stories but i have not tested it it may work) It cannot run windows 2000 and up because it is unsupported by Dosbox and by far its unsupported by bochs. a bit more info: The psp PHAT can emulate up to about 5 Megs of ram Just 1 meg above what windows 95 needs and thats BARE MINIMUM!!! The psp SLIM can emulate up to 16.5MB of ram which is about the recommended amount of ram for windows 95 ALso the psp's processor normally runs at 222MHz but can run at the full 333MHz its underclocked so that the battery lasts long and don't worry you wont damage your psp by running at a full 333MHz it will just eat up a battery like i eat up a macadamia nut cookie. So should i make an instructable?
Picture of Windows on a psp
1-10 of 45Next »
yourcat8 years ago
Which ARM does the PSP use? (7? 9? 11?)
since the psp runs at 33mhz, it won't be an arm11, because my phone has one and it's 396mhz
ReCreate (author)  yourcat8 years ago
Umm...I don't know, I do know that its clocked at 333MHz...
Sounds like a 9, but the psp is supposed to be so much more powerful than the ds, which uses a 7 and a 9.
the DS has a 111MHz ARM processor...
Except the DS has two...
And tha psp has 3...
yourcat yourcat8 years ago
3 arms?
And 4 legs
1-10 of 45Next »
