Wireless Button Pusher
Hello all,
I am trying to add/build a wireless button pusher to a grain management device on my farm. The device cannot be hacked into or tampered with, however, the button I am trying to push requires little force and does not need to be sustained. It only needs to hit the button when I hit a remote. Additionally, I cannot use a phone for this (my grandfather needs to be able to operate it as well and could not use a phone) So I would need to be able to connect two simple remotes.
Any and all suggestions welcome.
Anshu AR2 months ago
If I were building this thing, I would consider using hobby grade linear actuators with Arduino (Which is quite obvious).
OR
Now I don't know what kind of switch you are using. But try considering Relays. Using a relay will be a lot easier and simple.
Hope that helps :)
larx (author)  Anshu AR2 months ago
Thank you! I will look into relays if possible. The Arduino option might work as well
