3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Word formatting on comments
I have been away from Instructables for some time, and I came back, not much has changed after the pro feature was implanted. Which is good. ^^
However, I have a little problem with word formatting, when I tried using some symbols to change the way the words look, they don't work. Is this due to the pro feature? Or am I using the wrong symbles and my memory needs a little refreshing?
Thanks!
I just chose this picture randomly, I don't know what else to use. :P
8 comments
Apr 12, 2012. 11:22 PMamo123 says:
You can use the editor to edit the text. Test?
meizitang
Mar 5, 2010. 2:11 PMcaitlinsdad says:
While you were out, they changed the input editor.  And as a non-pro user, you are now limited to I think italic and bold formatting.  You have to use the button to embed the links. The other fancy stuff like super/subscript, strikeout, big, etc is only available to pro members.
You could start here to read up on the changes.
Welcome back.
Mar 5, 2010. 7:59 PMkelseymh says:
Unfortunately, the inline (text-based symbols) formatting does not work at all any more.  It really bugs me :-(  What you can do with a few simple things is use "control" keys:  bold is Ctrl-B, italic is Ctrl-I, and making a link is Ctrl-L.
If you decide to go for paid (pro) membership, then you get a bunch of additional formatting options, including "Source".  This allows you to type real HTML directly into your text, so you can do things like "<Strong>This would be in bold</Strong>" or "<Code>This is typewriter text</Code>", and so on.
Mar 5, 2010. 4:35 PMcaitlinsdad says:
Not sure, I don't think you can really play around with manually embedding the control codes.  You have to highlight text and use the buttons on the editor.  Experiment with it and see what works for you.
Mar 5, 2010. 5:22 PMGoodhart says:
Once you use some of the "functions" you can click source and see the HTML for each one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
