3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
World Studies Project on Steam Power
I'm doing a project for school on Steam power... It's origins, it's applications, the reason it died out, the future...Blah blah blah. Along with that, I will be building some small working models, a hero engine, and a piutt putt boat. I was wondering if anyone had any ideas for a beginner that would look nice and actually move? I have minimal building skills and funds, so i'm really looking for simple ideas. Thanks, James P.S. Any one realize the projectile potential of steam power? Real simple... Empty wine bottle, bit of water in bottle, cork it off...Need something more than tea candles i'd imagine...Could be fun! (I'm scaring my history teacher:D)
13 comments
Oct 1, 2007. 4:46 PMits a lion says:
i watched a history of the steam engine one day and they said that the ancient greeks invented it and it was used as a toy. it was a central tank with two "arms" coming off of it that the steam came out of. this caused it to spin on the supports that held it up. i drew a bad picture in paint kind of showing it. the arrows show the direction it would go and the little squiggly lines are the steam coming out. i forgot the fire, but there should be one under it. not sure if you can call it a "steam engine" however it is what they said the earliest account of using steam to power something.
Oct 1, 2007. 5:46 PMits a lion says:
i didnt read kitemans posts so sorry i missed it. yeah thats what i was talking about.
Sep 30, 2007. 10:57 AMKiteman says:
If you're googling, early steam engines were sometimes called fire engines. One of the earliest steam engines had no moving parts other than hand-controlled valves - it was used to pump water out of mines. A metal vessel was filled with steam, then cooled to create a vacuum which drew water up from the mine... Savery's Miners' Friend.
http://www.mgsteam.btinternet.co.uk/engdev.htm
Early versions had no external boiler, they just heated the vessel directly. With a little planning, it should be possible to recreate a model that will pump water from a low bucket to a high bucket.
Sep 29, 2007. 5:55 PMNachoMahma says:
. But it's still alive and well. Most of the electricity in the world is produced by steam - water is heated by coal/natural gas/nuclear reaction/&c and the steam drives a turbine which drives a generator.
. Lots of stuff on the 'Net already. At least on iBle on the subject.
> Empty wine bottle
. I would not recommend glass for any DIY steam projects. Never apply direct flame to glass that is not specifically designed for such use. IIRC, water expands something like 300x when turning into vapor - a LOT of pressure can be built up in a short time.
Sep 29, 2007. 6:59 PMNachoMahma says:
. Wow! The steam spider is cool. Looks like something from the Wild, Wild West movie.
Sep 29, 2007. 6:05 PMNachoMahma says:
. Oh! One of the main reasons steam is not in use by the general public is Economies of Scale. It's not very economical on a small scale. Maintenance costs alone on a steam turbine are high, even for a home/car-sized unit.
Sep 29, 2007. 4:10 PMPatrick Pending says:
Steam turbine: A jet of steam (from a narrow tube) is used to turn a turbine wheel. Make the turbine wheel from a circle of aluminium cut from a drinks can. Cut several slits from the circumference towards the center, twist the aluminium to form turbine blades. Make a hole in the middle and mount it on a wire axle. Cheers, Pat. Pending
Sep 29, 2007. 3:42 PMGoodhart says:
Whoops, didn't include the link sorry: One hour simple Steam project...
Sep 29, 2007. 3:40 PMGoodhart says:
I bet you are, especially if you try to heat the wine bottle LOL. That won't last long.
But anyway, here is one idea:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
