Wrap your cords like a pro
Keep your cables secure and tidy with these cord-wrapping techniques. I've used the first technique quite a bit, but the chain style looks like it's worth checking out.
What do you think? Is your cable kung fu better?
Link
Picture of Wrap your cords like a pro
1-10 of 17Next »
saintneko5 years ago
I use #2, after I saw a friend of a friend using it. They showed me how it was done and I've been with it ever since.
Though the figure-8 style is apparently very useful for wrapping short cords attached to power tools, which thanks to
https://www.instructables.com/id/How-to-Neatly-Wrap-Power-Tool-Chords/
I am now going to go try out on everything in the workshop.
garyomega9 years ago
As a retired contractor, I always used the "chain" method for cords. It was sometimes a source of great mirth to watch apprentices try to figure them out.
Yes! They just love starting from the wrong end
scafool9 years ago
I have tried both and watched my coworkers try untying them from the wrong end. I find the easiest way is to simply stuff the cord down into a bucket and leave the end of it hanging in a notch cut into the side of the bucket. If you work construction everything comes on those plastic buckets, and your only real competition for them is the dry-wallers who are getting their taping compound in boxes. If you have cords less than 100 feet long just put the plugs together as you feed them into the pail. If you remember to feed on order of length, and you have loaded short over long, you can just turn the whole mess upside down into another bucket and pull from that to get a long over short feed. (I tend to buy all of my extension cords in bulk and chop them into 50' lengths)
scafool scafool9 years ago
OH, but of your 2 options the chain is the easiest
Sandisk1duo9 years ago
i usually wrap cords, or long wires aroud my palm and elbow, just like how my grandmother taught me
Kiteman9 years ago
I recognise the first as a figure-of-eight coil, it's common amongst climbers for storing their ropes. The second one looks like finger-knitting, writ large...
gmoon Kiteman9 years ago
AFAIK, that's a Butterfly Coil.
I found a rather obscure reference on the web to a "figure of eight coil," which appears to be a standard mountaineer's coil. But never heard a climber use that term, probably because it conflicts with the figure eight knot, the most frequently used knot in climbing...
The second coil pic is actually used in climbing, too. I've always called that "daisy chaining," and it's used to store tubular webbing in a nice compact package that can be "unchained" with a single pull... ( example ) To make it confusing, an actual [http://en.wikipedia.org/wiki/Daisy_chain_(climbing)#Daisy_chain daisy chain] is something different...
Kiteman gmoon9 years ago
OK, I looked at the link, yes, you're right.
A figure-eight coil isn't doubled before the wrapping stage, it's doubled before the coil, then the bight is wrapped and threaded.
What we are suffering is poor nomenclature, probably worsened by a geographical and generational thing, since I learned my knots and climbing terms from Brits who are all at least 65 now and both sailed and climbed, so terms got mixed.
The one you link to as a mountaineer's coil, I call an alpine coil. The one you've called a figure-of-eight knot, I know as a figure-of-eight loop (although tying it in the working end instead of the bight is new to me - I'll have to explore that site some more). The daisy chain is a form of finger knitting, but it's also (to a scout taught by a sailor) a chain shortening.
Yeah, the terms are very regional.
And that butterfly coil? I called that a mountaineer's coil for 6 or 7 years. You adopt the nomenclature of your peers, right or wrong.... ;-)
"Finger Knitting" is a more descriptive term (but I'm not using it around my climbing mates...)
The figure eight is also used to spice two ropes together for rappelling. Although less often today, as most have adopted the perversely-named Euro Death Knot (the EDK slides over obstructions much better than any other "bend," so ropes don't get hung-up when you pull 'em...)
1-10 of 17Next »
