loading
Yet another challenge from TheDunkis
Here's a cool idea I had for awhile. It doesn't seem too practical but still pretty cool if you can pull it off. True Slide action. Basically it's the same as true bolt action in how it works. Make a handle loading pistol where the slide pushes a round from the loading chamber into the firing chamber for more power. It actually shouldn't be that hard. The most difficult part will probably be the trigger. To make it more of a challenge, try making it as compact as possible like a real pistol.
I might actually be able to build and review the winner's this time. I'll give you a basic image to give you an idea of what I'm looking for...but mostly just so I can get through the filter faster.
Picture of Yet another challenge from TheDunkis
1-10 of 44Next »
yerjoking7 years ago
Been there, done that. Sorta...
Remember? :P
Only problem I had was the trigger, the best I could come up with would be one infront of the mag, blocking infront, so unless someone can make a lucky sear type...
Wait, I'm talking about the other BA knex mech, where the bullet is covered then moved, instead of just being moved, allowing more accuracy since grey connectors allow less space than the reg style.
Either way, you saw the mech, and the gun.
You could try something like the trigger on my Jackal v4, I realized it could be used for bottom loading bolt actions lol.
But you have no idea what mech I'm talking about, around 4 people on this site possibly do.
Then why not be more specific?
Because I was talking to TD, also.
"Wait, I'm talking about the other BA knex mech, where the bullet is covered then moved, instead of just being moved, allowing more accuracy since grey connectors allow less space than the reg style"
That implies it's a diff mech.
Oh, I was tired lolz.
Understandable.
TheDunkis (author)  DJ Radio7 years ago
OMG DUDE STOP CLAIMING THAT TRIGGER! I made something exactly like it except with a different part for pulling it on the bottom. I put it into a failed BA too. I don't care if you thought it up on your own because I still thought it up first.
OMG DUDE IMMEDIATELY STOP SCREAMING!!!!
No pics, didn't happen.  I can't see the trigger in your failed BA either.
How can you not see it? Just click the image and look at the highest possible resolution. You can clearly see. Maybe you can't see the inside but it would obviously be the same in order to work.
1-10 of 44Next »
