loading
ZKAR problems. Any fixes?
Ok, so I've noticed an issue with the ZKAR (Both the breech loading and normal versions).  If I push the bolt forward too fast, it results in the round being loaded too far up the barrel, where the pin can't hit it and thus can't shoot it out of the gun.  Sometimes the round even sticks out of the gun.  A side effect of this issue is that the pin guide connection breaks when the gun is shot because at this point the failed shot is treated as a dry fire.
Any fixes?
1-10 of 19Next »
don't pust the bolt foward too fast then...
DJ Radio (author)  Fred the Penguin6 years ago
I like being able to use the extreme ROF the gun has?
and i like being able to hit a target that isn't at point blank?
The accuracy is reasonable enough if you use the sights.
thats kinda hard if the gun is jumping all over the place from rapid fire, exactly why sniper rifles are not fully automatic...
Zak can go slightly less than 1 per second and keep it steady.
but can he aim and hit targets 10m away at that speed?
knexguy6 years ago
What TD said, to solve it try using a triple folded #64 on the bullet lock.
DJ Radio (author)  knexguy6 years ago
#64's won't fit on my ZKAR bullet lock but I'll try it with different bands.
TheDunkis6 years ago
My guess is you need a stronger bullet lock then.
1-10 of 19Next »
