anyone want to help? very small led project...
I have carfuly painted a extra set of macbook keyboard keys that i have with phosphorescent clear paint. I want to mount a little (as small as i can possible make it) box onto of the screen, in the middle, with a uv led in it (doesnt need to be high powered) so that it will cause the keys to illuminate to there full potential. what i need help with is wireing the project. i dont wanna use a usb port so im going to use a male to female usb coupler (http://www.mpja.com/productview.asp?product=15477+PL)... i want to wire the led into that so it can plug in and power the led and i can still use the usb port... Does this sound possible? can anyone give me tips or help? any opinions would also be apreciated!
Embed a 3D viewer in your Instructable
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Got contest ideas? Want to help HQ staff?
Large Instructables Robot head made out of driftwood, check it out!
Call for pre-made parts!
The Instructables Green Design Contest is starting on Earth Day!
My instructable made it into Popular Science!
Orbotix wants to see your hacks - you could win a Sphero!
Visit Our Store »
Go Pro Today »
That being said:
I've ordered UV LEDs off of ebay from Hong Kong usually you have to buy a fairly quantity like 50 or 100. Mine came out to about $0.30 a piece. These UV LEDs require 3.4-3.6 volts and use need to have the current limited somewhere in the range of 30-50ma (30 - 50 milli-amps). I have read somewhere else on Instructables that you could get them out of a device used for brightening teeth.
To drop the 5V USB power subtract 3.6V from 5V = 1.4V this voltage needs to be 'dropped' down using a resistor. Which also limits the amount of current flowing through the LED. Dividing 5V by .05 Amps (Ohms Law) gives you a value of 28 ohms for the amount of resistance.
I believe USB power supply is current limited meaning that it is a "stiff" current source so you might be able to use a lower resistance like a 10 ohm resistor. I'm not a 100% on that so don't quote me.
As for connecting it the link in a previous post gave a nice tutorial on how to build this type of device.
Be sure to observe polarity, connect the cathode side of the LED to the negative wire. If you don't know what this means read up on it.
http://www.instructables.com/id/E1OSW5LM9YET9K4IMM/.
You'll need to make sure the values are consistent with UV leds as well. You'll probably want to use a cheap usb cable for the connector and to place the leds. Not sure what you meant by using a cheap cable extender - did you mean you wanted to plug this in, and still be able to use the usb port? You might be able to get away with it, but only if the devices don't draw much current.
Good luck!
http://www.josepino.com/circuits/index?usb_led_light.jpc
