loading
battery for an electric go kart?
hello, I'm planning on taking a box fan motor and attaching it to a frame.
what kind of battery should i use and what should the circuit include?
thanks
SC
Picture of battery for an electric go kart?
1-10 of 14Next »
can i make a go kart with 2 battries of 12 volt and a dc motor of 24 volt of 1 hp..
can i use ac motor ??
lemonie7 years ago
That fan is hardly going to move you (if it moves you at all). You want a 100c 2-stroke minimum, and an aero-propeller.
L
sc lightning (author)  lemonie7 years ago
No, no, no, sorry i don't think i explained my self enough. I'm attaching the motor to move the wheels, unlike an air boat type vehicle. Thanks for the quick reply, SC
This post is fairly old, and I don't care. Anyways, You can not use a DC Battery with an AC electric motor, Even if you were to convert DC to AC, you will need alot of batteries, or convert a 12 volt battery through an inverter to step up the voltage to 115 volts..
But then again, Nothing will work, your better off with an electric motor taken from an old wheelchair (They have fairly large, 12 volt motors that are capable of moving you up to 20, to 25 miles per hour, providing that you remove the gear box assembly, why would an old person want to travel 25 miles per hour? to get to the store faster?)
BTW, that was not sarcasm. Here is an example of a good set up.
4x twelve volt batteries, wired in parallel for AMPERAGE, or AMP hour.
1x twelve volt, 20 amp motor (HQ Wheel Chair)
1x steering assembly, and driveshaft, (means of hooking up the motor to the wheel.
The steering is fairly easy, all you need to do for that is have a bar with a loop in the middle, with a shaft going up for the steering wheel, So when you turn the wheel, the wheels move with it.
As for the driveshaft assembly, The easiest and lightest way to do this, is to use one motor on one rear wheel, There is no drag, or faster wearing of the tires, so don't worry. You should be able to go a good 110 miles before running out of battery..
Which in my opinion, I'd use for everyday traveling, I'd visit my old neighborhood everyday which is 5 miles away, and 5 miles back, (10 miles total a day). or off to radio shack and back (30 miles)
I'm guessing the back end of an electric scooter (the motor and wheel assembly) would work as well with enough power and suitably rated cabling for it?
Long time ago, apologies.. Yes, it would. The more batteries you wire in parallel, the longer you will go. Just don't over volt the motor too much.
For an electric scooter motor, you would probably need somewhere aroung 10-12 gauge wiring.
You'd do better blowing yourself (or sucking).
That motor is "weedy" you won't move.
Car starter-motor or a decent 12/24V thing is what you need. Look here for the same sort of thing:
https://www.instructables.com/tag/?sort=none&limit%3Atype%3Aid=on&q=electric+bike
L
Koosie lemonie7 years ago
Awesome idea with that car starter. How long do you think a fully charged normal car battery should last? With not much torque needed for the blade, would it also spin a lot faster?
.  Most automotive starters would have enough torque/power but they generate a lot of heat and are designed to run for about 10 seconds at a time. They are not rated for continuous duty.
Fans are notoriously inefficient. I'd go with a chain or friction drive straight to the wheel(s).
sc lightning (author)  NachoMahma6 years ago
that's my goal. should i use a car battery? and how do i connect the circuit?
1-10 of 14Next »
