loading
battery problem
i have a 12 volt 7ah rechargeable lead-calcium battery, but no charger. i want to build a charger, but the diagrams ive found are for lead acid. does anyone have a good circuit for lead calcium battery chargers?
12V7 years ago
the only difference is that a lead calcium battery battery can cope with up to 15v charging current i charge my sla(most of which are calcium) on 13.8v usually they will charge with a normal charger(9times out of 10 it does and it is totally safe) the only difference is they don't dry up as quickly.(as a standard battery)
Sandisk1duo8 years ago
What? lead-calcium? if i were you, i'd build a very low amperage, 500ma psu, then check the voltage periodically, keep it outside, and away form anything you don't want to destroy
guyfrom7up8 years ago
bump I'll answer the question in like 10 minutes
woah, i thought you said nickel cadmium, I never hear lead-calcium I'll look into it
tech-king (author) 8 years ago
bump
tech-king (author) 9 years ago
bump. fast!
