ben heck a/v selector, alternate chips
He uses a bus switch, CBT3244A, Digi-Key part # 568-3619-5-ND (out of stock I believe). While I could order a comparable bus switch, I have several lying around from hacking apart a kid's toy. 74hc374.
I've looked at the datasheets and, I've never been very adept at understanding them, preferring the lazymans terms. I understand that the original chip has 2 switches (to use for two separate a/v connections, or turning both on for a connection with more pins) while the chip I have has only one switch, allowing up to 8 channels to go through.
What I'm confused about is the state of the "on" switch for the one I have, or maybe the clock. From what I understand, they each need to be pulled LOW (connected to ground) in order for their respective inputs to flow through, can the clock, in my case, be ignored?
For the arduino tags, I do plan to make this project remote controlled. But I'm a serious beginner in this area. Basically I plan to replicate this project for arduino. http://www.tauntek.com/tinyir2-learning-ir-remote-control-receiver.htm Would there be a point to that? Or would it be simpler to just order the chip by itself already programmed. I think that programmed tinyir2 PIC chip and arduino chips come out around the same price wise. I have the other components lying around already.
5
comments
Add Comment
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
