broken lcd controller lcd works great
i have a 20" lcd tv with a broken controller in it  is there any lcd controller kit that would work good with a 20"  lcd screen
mybad  its a 26"  Maxent MX-26X3
thanks
vicz (author) 7 years ago
MX-26X3
1. 26” 16:9 WXGA LCD Display
2. 16.77 Million Colors
3. High Contrast Ratio (800:1)
4. High Brightness (500 cd/m2)
5. Multi-scanning PC Monitor Support Up to 1280 x 1024
6. 170 Degrees Viewing Angle
7. RS-232 Control Port
8. Built-In Speaker: 10W + 10W
Specification
MX-26X3
Display
Screen Size
575.77 mm x 323.71 mm (26” Diagonal)
Aspect Ratio
16 : 9
Pixel Resolution
1366 (H) x 768 (V)
Pixel Pitch
0.4215 mm (H) x 0.4215 mm (V)
Contrast Ratio
800 : 1
Brightness
500 cd/m²
Displayable Colors
Viewing Angle
170˚
Response Time
12 msec
Signals
Synchronization (Auto Detect)
Horizontal Frequency
15KHz / 31~69 KHz
Vertical Frequency
60 Hz
Video System
480i, 480p, 720p, 1080i SDTV/EDTV/HDTV, NTSC
RGB Resolution
Up to 1280 x 1024 (SXGA)
RGB/DVI
DVI Input (with HDCP)
DVI-D 24 pin x 1
RGB Input
D-Sub 15-pin x 1
RGB Output
D-Sub 15-pin x 1
Audio Input
RCA-pin (L/R) x 2 Sets
Audio
Integrated Speaker Output
10W x 2
Video Capability
NTSC Tuner Input
RF 181CH x 1
Composite Video Input
RCA-pin x 2
S-Video Input
Mini DIN 4-pin x 2
Component Video Input
RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect)
Audio Input
RCA-pin (L/R) x 4 Sets
Audio Output
RCA-pin (L/R) x 1 Set
External Subwoofer Output
RCA-pin Type x 1
Control Port
RS-232
D-Sub 9-pin x 1
General
Power Supply
100V~240V/50~60Hz
Power Consumption
180W +/- 10%
Dimensions W/Stand
870.6mm x482.7mm x225.6mm/34.27"x 19.00"x 8.88"
WO/Stand
870.6mm x416.8mm x107.4mm/34.27"x 16.40"x 4.23"
Weight W/Stand
28.20 lbs
WO/Stand
22.04 lbs
Optional Accessory
Wall Mount Bracket
Horizontal Mount with 4 Selectable Inclination Angles
Design and specifications are subject to change without notice.
lemonie7 years ago
Yes probably, or you might get a replacement board.
You/we'd need to know the exact LCD/controller to advise any further.
L
