Lomography Konstructor - World's First 35mm DIY SLR
Office Warfare Book on Sale Now
List of Upcoming Contests (updated 6/6)
Spanish translations of Instructables / Instructables traducidos al Espanol
If you Need Help with your English Instructable - I'll Help Edit & Fix it Up
JULY 2013 Build Night with SUGRU
High-current, electronic sword-fighting, fancy drink pouring, and more @ Makers Local 256 Build Night!
New Instructables Books for 2013
Souped Up: Projects to Make Everything Better [Book]
Backyard Rockets Book on Sale Now
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Then you'd need to decide what angles you were going to hang the shelves at - you can see in the photo that the maker has cut small notches in the angled shelves so that the books can sit upright.
That would be the trickiest part, I bet, but you you could just draw the design onto the shelf front and then cut it away.
This one is quite easy actually...
Get yourself three usefull ikea shelves. See how they should be mounted and if you could make some extra mountings yourself (or buy them there ofcourse)
Then when you get home cut the shelves into pieces. Now when you look closely at the picture you'll see that at both ends of each piece of shelve there is a metal piece mounted that keeps the books in place.
Cut out some metal T pieces and mount the to the bookshelves using screws then bend the metal piece so it keeps the books in place.
Then mount the shelves and you are done :)
Make an ible for it if you do it ;)
Michel
