loading
can i talk to multiple arduinos at the same time with another arduino, in a serial format?
Hello all,
I am trying to talk to multiple (say 4) microcontrollers (Arduinos) at the same time. I was wondering if i can setup a serial connection, with a selection line that can detect the neighbor Arduino and enable the corresponding pin to start the serial communication between the two. something like this:
Like what? ;)
I can't see a thing...
But there is good documentation about serial communication in the Arduino forums and help pages.
karimskarim (author)  Downunder35m1 year ago
Sorry; I am not sure why did not attach. It is here now (below):
I mean multiple serial communication. Is that possible with Arduino Micro? I am not sure what pins and how many of them are available to use for serial (not master/slave) communication.
thank you, but I2C would as you know be a master/slave based protocol. I would like to have the option of interchanging the center Arduino with any of the surrounding ones. Hence wondering if a serial connection would do that? and if yes, how would i create multiple of those with one Arduino micro. Would I need some sort of shield/module for that?
For the "real" thing:
https://www.arduino.cc/en/Tutorial/MultiSerialMega
(Has some nice examples)
https://www.arduino.cc/en/Reference/softwareSerial
Since the micro has no serial chip it has to be done by software and free pins.
AFAK there is no shield for this as the serial communication can be done by software.
Problem I see is the available pins on the micro - you might need to use something with more usable pins depending on your project.
Thank you very much. Sorry for the delay but I needed to investigate it a bit more. It just may be exactly what i need, since each serial connection provides power and data at the same time. However as I already have a bunch of Arduino MIcros I am hoping to implement the AltSoftSerial on them. Now I was looking into the specs and pinouts of Micro, and I cannot make certain exactly which pins are usable for AltSoftSerial. Would you happen to know this? On this link:
http://www.pjrc.com/teensy/td_libs_AltSoftSerial.h...
it mentions the pins for Leonardo and Mega. and Uno.
Do I have a chance? I need 6 simultaneous serial connections. So, a 5V bus and a GND line for all, and then 6 RX and 6 TX pins. Am I correct?
Regards,
Karim.
I am sorry but there is little help I can offer here as I have not done enough serial com stuff with my Arduino :(
