3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
capacitors Preventing sparking
im trying to build a sollenoid motor like this one
http://www.youtube.com/watch?v=e3tcdiO2HCc&feature=channel
and i need to no how to prevent sparking on the switch so that im not constantly having to replace it. ive heard somewhere that a capacitor will prevent a spark on the switch but will it? and how big of one will i need. thanks
29 comments
Aug 5, 2011. 10:59 PMÆ says:
Yes, you can add a capacitor across contact terminals, it's called a snubber. Same as the "condenser" on a an old fashioned car distributor with breaker points. Absorbs the arc/spark. A MOV can be used too, because it looks (measures) like a capacitor. You have to determine the amount of capacitance empirically. Add small amounts, start with .1uF and add additional amounts until the spark has subsided.
May 23, 2010. 2:59 PMaeronut01 says:
Has anyone mentioned trying a varistor?  The website   www.phonda.com.tw/varistor.htm clearly describes its function.  Basically, its a resistor that varies from almost non-conductive to very conductive depending on the voltage fed into it.  You wire it in parallel to the switch and the next time a spark heads to the switch, the varistor should absorb the spike in electricity.  BTW, a varistor is also called a "metal oxide varistor" or "MOV".  If that doesn't work, try a ZNR (Zinc Resistor), but the MOV should work just fine.
Feb 12, 2009. 2:08 PMlemonie says:
You could use a solid-state switch, something with silicon in it? L
Feb 16, 2009. 9:56 AMPlasmana says:
Well, the semiconductor will burn out from the voltage spikes. it will still require some form of protection.
Feb 11, 2009. 6:17 PMGoodhart says:
On the solenoid, do you have a diode to suppress the spike kick back you get when the induction field created by the voltage from the coil of the solenoid, collapses?
Feb 11, 2009. 6:27 PMGoodhart says:
That'll work for the transformer. Anytime I incorporate a relay or a solenoid or anything with a coil, I double check to make sure there is a diode across that coil. Such feedback can do damage to equipment, and also cause a heck of a flash back at the switch when it is opened.
Feb 11, 2009. 7:06 PMNachoMahma says:
. A capacitor accomplishes the same thing as a diode. Caps are usually rated for higher voltages.
Feb 11, 2009. 9:42 PMGoodhart says:
Higher then say the 1n4007 ? ;-)
Feb 12, 2009. 5:13 AM11010010110 says:
a capacitor gets the shock. a diode shorts it out so no need to use diode of high voltage but - capacitor can be used on ac and diode no
Feb 15, 2009. 5:44 PMtech-king says:
caps can ONLY be used on ac for this application. unless you mean from power to ground to filter the spike?
Feb 15, 2009. 6:07 PM11010010110 says:
caps can be used on dc too the spike herre is across the switch a cap in parallel to the switch takes the spike and does not pass dc when the switch is open
Feb 12, 2009. 7:38 AMGoodhart says:
True, the voltage rating of the diode is it's reverse breakdown voltage limit
Feb 12, 2009. 3:42 PMGoodhart says:
Hmm? The transformer? That generates an electro-magnetic field, and when the switch cuts the current, the field collapses causing a reverse voltage spike that is greater then the input was. This can cause back flash (spark) that can damage equipment and ruin the switch. We were discussing whether a diode or a capacitor is best to use to suppress that particular arc. I have to agree that a cap would serve well in this case.
Feb 11, 2009. 2:19 PM11010010110 says:
its parallel to the switch. i guess 0.1 uF 600 V is about ok but not sure
Feb 11, 2009. 6:30 PM11010010110 says:
then the motor wont work
Feb 11, 2009. 2:27 PMNachoMahma says:
. The condenser from an old (points) automotive ignition should work. . Or get a switch with a higher interrupting current (AIC) rating.
Feb 11, 2009. 6:00 PM11010010110 says:
a massive switch won't mind sparking but you should use appropriate materials (so it won't heat cause of high resistance) and isolate well yourself from the switch insides
Feb 11, 2009. 6:29 PM11010010110 says:
no need to go that far aluminium for example is good conductor but idk if it stands sparks well. iron is not as good so i think it should make more sparks as for heating - use large parts of whatever material. resistance goes down when thickness of parts goes up
Feb 15, 2009. 5:48 PMtech-king says:
aluminum is a good conductor, but it fast increases in resistance as it heats up. the ideal material for parts subjected to sparks, arc, thermal shock and heat is tungsten. its also very hard to work with. steel and aluminum pit from arcing, which in turn causes corona loss problems and spark trigger misfires.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
