loading
changing admins password
ok i was wonding if it would be possible to change the admin's password using cmd being run as administrator (net user administrator *) then signing in with that account then going to control panel internet options and unblocking it that is my idea but would this be safe and can you even sign in with the admins account on your laptop
1-10 of 13Next »
pbmoose6 years ago
List of running processes as seen in safe mode. As far as i can tell, everything useful is blocked. Sorry about the formatting, i'ts how windows savedf it. If anyone wants i can write something to tablify it
Name Description Status Startup Type Log On As
ActiveX Installer (AxInstSV) Provides User Account Control validation for the installation of ActiveX controls from the Internet and enables management of ActiveX control installation based on Group Policy settings. This service is started on demand and if disabled the installation of ActiveX controls will behave according to default browser settings. Manual Local System
Adaptive Brightness Monitors ambient light sensors to detect changes in ambient light and adjust the display brightness. If this service is stopped or disabled, the display brightness will not adapt to lighting conditions. Manual Local Service
Adobe Active File Monitor V8 Tracks files that are managed by Elements Organizer Automatic Local System
Adobe Version Cue CS4 Adobe Version Cue CS4 Manual Local Service
Apple Mobile Device Provides the interface to Apple mobile devices. Automatic Local System
Application Experience Processes application compatibility cache requests for applications as they are launched Manual Local System
Application Identity Determines and verifies the identity of an application. Disabling this service will prevent AppLocker from being enforced. Automatic Local Service
Application Information Facilitates the running of interactive applications with additional administrative privileges. If this service is stopped, users will be unable to launch applications with the additional administrative privileges they may require to perform desired user tasks. Manual Local System
Application Layer Gateway Service Provides support for 3rd party protocol plug-ins for Internet Connection Sharing Manual Local Service
Application Management Processes installation, removal, and enumeration requests for software deployed through Group Policy. If the service is disabled, users will be unable to install, remove, or enumerate software deployed through Group Policy. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
Background Intelligent Transfer Service Transfers files in the background using idle network bandwidth. If the service is disabled, then any applications that depend on BITS, such as Windows Update or MSN Explorer, will be unable to automatically download programs and other information. Automatic (Delayed Start) Local System
Base Filtering Engine The Base Filtering Engine (BFE) is a service that manages firewall and Internet Protocol security (IPsec) policies and implements user mode filtering. Stopping or disabling the BFE service will significantly reduce the security of the system. It will also result in unpredictable behavior in IPsec management and firewall applications. Started Automatic Local Service
BitLocker Drive Encryption Service BDESVC hosts the BitLocker Drive Encryption service. BitLocker Drive Encryption provides secure startup for the operating system, as well as full volume encryption for OS, fixed or removable volumes. This service allows BitLocker to prompt users for various actions related to their volumes when mounted, and unlocks volumes automatically without user interaction. Additionally, it stores recovery information to Active Directory, if available, and, if necessary, ensures the most recent recovery certificates are used. Stopping or disabling the service would prevent users from leveraging this functionality. Manual Local System
Block Level Backup Engine Service The WBENGINE service is used by Windows Backup to perform backup and recovery operations. If this service is stopped by a user, it may cause the currently running backup or recovery operation to fail. Disabling this service may disable backup and recovery operations using Windows Backup on this computer. Manual Local System
Blue Coat ProxyClient Accelerates application traffic and provides Web filtering for mobile users. Started Automatic Local System
Bluetooth Support Service The Bluetooth service supports discovery and association of remote Bluetooth devices. Stopping or disabling this service may cause already installed Bluetooth devices to fail to operate properly and prevent new devices from being discovered or associated. Manual Local Service
Bonjour Service Bonjour allows applications like iTunes and Safari to advertise and discover services on the local network. Having Bonjour running enables you to connect to hardware devices like Apple TV and software services like iTunes sharing and AirTunes. If you disable Bonjour, any network service that explicitly depends on it will fail to start. Automatic Local System
BranchCache This service caches network content from peers on the local subnet. Manual Network Service
Certificate Propagation Copies user certificates and root certificates from smart cards into the current user's certificate store, detects when a smart card is inserted into a smart card reader, and, if needed, installs the smart card Plug and Play minidriver. Manual Local System
CNG Key Isolation The CNG key isolation service is hosted in the LSA process. The service provides key process isolation to private keys and associated cryptographic operations as required by the Common Criteria. The service stores and uses long-lived keys in a secure process complying with Common Criteria requirements. Started Manual Local System
COM+ Event System Supports System Event Notification Service (SENS), which provides automatic distribution of events to subscribing Component Object Model (COM) components. If the service is stopped, SENS will close and will not be able to provide logon and logoff notifications. If this service is disabled, any services that explicitly depend on it will fail to start. Automatic Local Service
COM+ System Application Manages the configuration and tracking of Component Object Model (COM)+-based components. If the service is stopped, most COM+-based components will not function properly. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
Computer Browser Maintains an updated list of computers on the network and supplies this list to computers designated as browsers. If this service is stopped, this list will not be updated or maintained. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
Credential Manager Provides secure storage and retrieval of credentials to users, applications and security service packages. Manual Local System
Cryptographic Services Provides four management services: Catalog Database Service, which confirms the signatures of Windows files and allows new programs to be installed; Protected Root Service, which adds and removes Trusted Root Certification Authority certificates from this computer; Automatic Root Certificate Update Service, which retrieves root certificates from Windows Update and enable scenarios such as SSL; and Key Service, which helps enroll this computer for certificates. If this service is stopped, these management services will not function properly. If this service is disabled, any services that explicitly depend on it will fail to start. Started Automatic Network Service
DCOM Server Process Launcher The DCOMLAUNCH service launches COM and DCOM servers in response to object activation requests. If this service is stopped or disabled, programs using COM or DCOM will not function properly. It is strongly recommended that you have the DCOMLAUNCH service running. Started Automatic Local System
Desktop Window Manager Session Manager Provides Desktop Window Manager startup and maintenance services Automatic Local System
DHCP Client Registers and updates IP addresses and DNS records for this computer. If this service is stopped, this computer will not receive dynamic IP addresses and DNS updates. If this service is disabled, any services that explicitly depend on it will fail to start. Started Automatic Local Service
Diagnostic Policy Service The Diagnostic Policy Service enables problem detection, troubleshooting and resolution for Windows components. If this service is stopped, diagnostics will no longer function. Automatic Local Service
Diagnostic Service Host The Diagnostic Service Host is used by the Diagnostic Policy Service to host diagnostics that need to run in a Local Service context. If this service is stopped, any diagnostics that depend on it will no longer function. Manual Local Service
Diagnostic System Host The Diagnostic System Host is used by the Diagnostic Policy Service to host diagnostics that need to run in a Local System context. If this service is stopped, any diagnostics that depend on it will no longer function. Manual Local System
Disk Defragmenter Provides Disk Defragmentation Capabilities. Manual Local System
Distributed Link Tracking Client Maintains links between NTFS files within a computer or across computers in a network. Automatic Local System
Distributed Transaction Coordinator Coordinates transactions that span multiple resource managers, such as databases, message queues, and file systems. If this service is stopped, these transactions will fail. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Network Service
DNS Client The DNS Client service (dnscache) caches Domain Name System (DNS) names and registers the full computer name for this computer. If the service is stopped, DNS names will continue to be resolved. However, the results of DNS name queries will not be cached and the computer's name will not be registered. If the service is disabled, any services that explicitly depend on it will fail to start. Started Automatic Network Service
Encrypting File System (EFS) Provides the core file encryption technology used to store encrypted files on NTFS file system volumes. If this service is stopped or disabled, applications will be unable to access encrypted files. Started Automatic Local System
Extensible Authentication Protocol The Extensible Authentication Protocol (EAP) service provides network authentication in such scenarios as 802.1x wired and wireless, VPN, and Network Access Protection (NAP). EAP also provides application programming interfaces (APIs) that are used by network access clients, including wireless and VPN clients, during the authentication process. If you disable this service, this computer is prevented from accessing networks that require EAP authentication. Started Manual Local System
Fax Enables you to send and receive faxes, utilizing fax resources available on this computer or on the network. Manual Network Service
FLEXnet Licensing Service This service performs licensing functions on behalf of FLEXnet enabled products. Manual Local System
Function Discovery Provider Host The FDPHOST service hosts the Function Discovery (FD) network discovery providers. These FD providers supply network discovery services for the Simple Services Discovery Protocol (SSDP) and Web Services – Discovery (WS-D) protocol. Stopping or disabling the FDPHOST service will disable network discovery for these protocols when using FD. When this service is unavailable, network services using FD and relying on these discovery protocols will be unable to find network devices or resources. Manual Local Service
Function Discovery Resource Publication Publishes this computer and resources attached to this computer so they can be discovered over the network. If this service is stopped, network resources will no longer be published and they will not be discovered by other computers on the network. Manual Local Service
Group Policy Client The service is responsible for applying settings configured by administrators for the computer and users through the Group Policy component. If the service is stopped or disabled, the settings will not be applied and applications and components will not be manageable through Group Policy. Any components or applications that depend on the Group Policy component might not be functional if the service is stopped or disabled. Automatic Local System
Health Key and Certificate Management Provides X.509 certificate and key management services for the Network Access Protection Agent (NAPAgent). Enforcement technologies that use X.509 certificates may not function properly without this service Manual Local System
HomeGroup Provider Performs networking tasks associated with configuration and maintenance of homegroups. If this service is stopped or disabled, your computer will be unable to detect other homegroups and your homegroup might not work properly. It is recommended that you keep this service running. Manual Local Service
Human Interface Device Access Enables generic input access to Human Interface Devices (HID), which activates and maintains the use of predefined hot buttons on keyboards, remote controls, and other multimedia devices. If this service is stopped, hot buttons controlled by this service will no longer function. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
IKE and AuthIP IPsec Keying Modules The IKEEXT service hosts the Internet Key Exchange (IKE) and Authenticated Internet Protocol (AuthIP) keying modules. These keying modules are used for authentication and key exchange in Internet Protocol security (IPsec). Stopping or disabling the IKEEXT service will disable IKE and AuthIP key exchange with peer computers. IPsec is typically configured to use IKE or AuthIP; therefore, stopping or disabling the IKEEXT service might result in an IPsec failure and might compromise the security of the system. It is strongly recommended that you have the IKEEXT service running. Manual Local System
Interactive Services Detection Enables user notification of user input for interactive services, which enables access to dialogs created by interactive services when they appear. If this service is stopped, notifications of new interactive service dialogs will no longer function and there might not be access to interactive service dialogs. If this service is disabled, both notifications of and access to new interactive service dialogs will no longer function. Manual Local System
Internet Connection Sharing (ICS) Provides network address translation, addressing, name resolution and/or intrusion prevention services for a home or small office network. Disabled Local System
IP Helper Provides tunnel connectivity using IPv6 transition technologies (6to4, ISATAP, Port Proxy, and Teredo), and IP-HTTPS. If this service is stopped, the computer will not have the enhanced connectivity benefits that these technologies offer. Automatic Local System
iPod Service iPod hardware management services Manual Local System
IPsec Policy Agent Internet Protocol security (IPsec) supports network-level peer authentication, data origin authentication, data integrity, data confidentiality (encryption), and replay protection. This service enforces IPsec policies created through the IP Security Policies snap-in or the command-line tool "netsh ipsec". If you stop this service, you may experience network connectivity issues if your policy requires that connections use IPsec. Also,remote management of Windows Firewall is not available when this service is stopped. Started Manual Network Service
KtmRm for Distributed Transaction Coordinator Coordinates transactions between the Distributed Transaction Coordinator (MSDTC) and the Kernel Transaction Manager (KTM). If it is not needed, it is recommended that this service remain stopped. If it is needed, both MSDTC and KTM will start this service automatically. If this service is disabled, any MSDTC transaction interacting with a Kernel Resource Manager will fail and any services that explicitly depend on it will fail to start. Manual Network Service
Link-Layer Topology Discovery Mapper Creates a Network Map, consisting of PC and device topology (connectivity) information, and metadata describing each PC and device. If this service is disabled, the Network Map will not function properly. Manual Local Service
Media Center Extender Service Allows Media Center Extenders to locate and connect to the computer. Disabled Local Service
Microsoft .NET Framework NGEN v2.0.50727_X86 Microsoft .NET Framework NGEN Manual Local System
Microsoft Forefront Client Security Antimalware Service Helps protect users from spyware and other potentially unwanted software Started Automatic Local System
Microsoft Forefront Client Security State Assessment Service Helps protect users by providing security state analysis services to the Microsoft Forefront Security Suite. Automatic Local System
Microsoft iSCSI Initiator Service Manages Internet SCSI (iSCSI) sessions from this computer to remote iSCSI target devices. If this service is stopped, this computer will not be able to login or access iSCSI targets. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
Microsoft Office Diagnostics Service Run portions of Microsoft Office Diagnostics. Manual Local System
Microsoft Software Shadow Copy Provider Manages software-based volume shadow copies taken by the Volume Shadow Copy service. If this service is stopped, software-based volume shadow copies cannot be managed. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
Multimedia Class Scheduler Enables relative prioritization of work based on system-wide task priorities. This is intended mainly for multimedia applications. If this service is stopped, individual tasks resort to their default priority. Automatic Local System
Net Driver HPZ12 Automatic Local Service
Net.Tcp Port Sharing Service Provides ability to share TCP ports over the net.tcp protocol. Disabled Local Service
Netlogon Maintains a secure channel between this computer and the domain controller for authenticating users and services. If this service is stopped, the computer may not authenticate users and services and the domain controller cannot register DNS records. If this service is disabled, any services that explicitly depend on it will fail to start. Started Automatic Local System
Network Access Protection Agent The Network Access Protection (NAP) agent service collects and manages health information for client computers on a network. Information collected by NAP agent is used to make sure that the client computer has the required software and settings. If a client computer is not compliant with health policy, it can be provided with restricted network access until its configuration is updated. Depending on the configuration of health policy, client computers might be automatically updated so that users quickly regain full network access without having to manually update their computer. Manual Network Service
Network Connections Manages objects in the Network and Dial-Up Connections folder, in which you can view both local area network and remote connections. Started Manual Local System
Network List Service Identifies the networks to which the computer has connected, collects and stores properties for these networks, and notifies applications when these properties change. Started Manual Local Service
Network Location Awareness Collects and stores configuration information for the network and notifies programs when this information is modified. If this service is stopped, configuration information might be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start. Started Automatic Network Service
Network Store Interface Service This service delivers network notifications (e.g. interface addition/deleting etc) to user mode clients. Stopping this service will cause loss of network connectivity. If this service is disabled, any other services that explicitly depend on this service will fail to start. Started Automatic Local Service
Office Source Engine Saves installation files used for updates and repairs and is required for the downloading of Setup updates and Watson error reports. Manual Local System
Offline Files The Offline Files service performs maintenance activities on the Offline Files cache, responds to user logon and logoff events, implements the internals of the public API, and dispatches interesting events to those interested in Offline Files activities and changes in cache state. Automatic Local System
Parental Controls This service is a stub for Windows Parental Control functionality that existed in Vista. It is provided for backward compatibility only. Manual Local Service
Peer Name Resolution Protocol Enables serverless peer name resolution over the Internet using the Peer Name Resolution Protocol (PNRP). If disabled, some peer-to-peer and collaborative applications, such as Remote Assistance, may not function. Manual Local Service
Peer Networking Grouping Enables multi-party communication using Peer-to-Peer Grouping. If disabled, some applications, such as HomeGroup, may not function. Manual Local Service
Peer Networking Identity Manager Provides identity services for the Peer Name Resolution Protocol (PNRP) and Peer-to-Peer Grouping services. If disabled, the Peer Name Resolution Protocol (PNRP) and Peer-to-Peer Grouping services may not function, and some applications, such as HomeGroup and Remote Assistance, may not function correctly. Manual Local Service
Performance Logs & Alerts Performance Logs and Alerts Collects performance data from local or remote computers based on preconfigured schedule parameters, then writes the data to a log or triggers an alert. If this service is stopped, performance information will not be collected. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local Service
Plug and Play Enables a computer to recognize and adapt to hardware changes with little or no user input. Stopping or disabling this service will result in system instability. Started Automatic Local System
Pml Driver HPZ12 Automatic Local Service
PnP-X IP Bus Enumerator The PnP-X bus enumerator service manages the virtual network bus. It discovers network connected devices using the SSDP/WS discovery protocols and gives them presence in PnP. If this service is stopped or disabled, presence of NCD devices will not be maintained in PnP. All pnpx based scenarios will stop functioning. Manual Local System
PNRP Machine Name Publication Service This service publishes a machine name using the Peer Name Resolution Protocol. Configuration is managed via the netsh context 'p2p pnrp peer' Manual Local Service
Portable Device Enumerator Service Enforces group policy for removable mass-storage devices. Enables applications such as Windows Media Player and Image Import Wizard to transfer and synchronize content using removable mass-storage devices. Manual Local System
Power Manages power policy and power policy notification delivery. Started Automatic Local System
Print Spooler Loads files to memory for later printing Automatic Local System
Problem Reports and Solutions Control Panel Support This service provides support for viewing, sending and deletion of system-level problem reports for the Problem Reports and Solutions control panel. Manual Local System
Program Compatibility Assistant Service This service provides support for the Program Compatibility Assistant (PCA). PCA monitors programs installed and run by the user and detects known compatibility problems. If this service is stopped, PCA will not function properly. Manual Local System
Protected Storage Provides protected storage for sensitive data, such as passwords, to prevent access by unauthorized services, processes, or users. Manual Local System
Quality Windows Audio Video Experience Quality Windows Audio Video Experience (qWave) is a networking platform for Audio Video (AV) streaming applications on IP home networks. qWave enhances AV streaming performance and reliability by ensuring network quality-of-service (QoS) for AV applications. It provides mechanisms for admission control, run time monitoring and enforcement, application feedback, and traffic prioritization. Manual Local Service
Remote Access Auto Connection Manager Creates a connection to a remote network whenever a program references a remote DNS or NetBIOS name or address. Manual Local System
Remote Access Connection Manager Manages dial-up and virtual private network (VPN) connections from this computer to the Internet or other remote networks. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
Remote Desktop Configuration Remote Desktop Configuration service (RDCS) is responsible for all Remote Desktop Services and Remote Desktop related configuration and session maintenance activities that require SYSTEM context. These include per-session temporary folders, RD themes, and RD certificates. Manual Local System
Remote Desktop Services Allows users to connect interactively to a remote computer. Remote Desktop and Remote Desktop Session Host Server depend on this service. To prevent remote use of this computer, clear the checkboxes on the Remote tab of the System properties control panel item. Manual Network Service
Remote Desktop Services UserMode Port Redirector Allows the redirection of Printers/Drives/Ports for RDP connections Manual Local System
Remote Procedure Call (RPC) The RPCSS service is the Service Control Manager for COM and DCOM servers. It performs object activations requests, object exporter resolutions and distributed garbage collection for COM and DCOM servers. If this service is stopped or disabled, programs using COM or DCOM will not function properly. It is strongly recommended that you have the RPCSS service running Started Automatic Network Service
Remote Procedure Call (RPC) Locator In Windows 2003 and earlier versions of Windows, the Remote Procedure Call (RPC) Locator service manages the RPC name service database. In Windows Vista and later versions of Windows, this service does not provide any functionality and is present for application compatibility. Manual Network Service
Remote Procedure Call (RPC) Net Automatic Local System
Remote Registry Enables remote users to modify registry settings on this computer. If this service is stopped, the registry can be modified only by users on this computer. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local Service
Routing and Remote Access Offers routing services to businesses in local area and wide area network environments. Disabled Local System
RPC Endpoint Mapper Resolves RPC interfaces identifiers to transport endpoints. If this service is stopped or disabled, programs using Remote Procedure Call (RPC) services will not function properly. Started Automatic Network Service
SeaPort Enables the detection, download and installation of up-to-date configuration files for Microsoft Search Enhancement applications. Also provides server communication for the customer experience improvement program. If this service is disabled, search enhancement features such as search history may not work correctly. Automatic Local System
Secondary Logon Enables starting processes under alternate credentials. If this service is stopped, this type of logon access will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
Secure Socket Tunneling Protocol Service Provides support for the Secure Socket Tunneling Protocol (SSTP) to connect to remote computers using VPN. If this service is disabled, users will not be able to use SSTP to access remote servers. Manual Local Service
Security Accounts Manager The startup of this service signals other services that the Security Accounts Manager (SAM) is ready to accept requests. Disabling this service will prevent other services in the system from being notified when the SAM is ready, which may in turn cause those services to fail to start correctly. This service should not be disabled. Automatic Local System
Security Center The WSCSVC (Windows Security Center) service monitors and reports security health settings on the computer. The health settings include firewall (on/off), antivirus (on/off/out of date), antispyware (on/off/out of date), Windows Update (automatically/manually download and install updates), User Account Control (on/off), and Internet settings (recommended/not recommended). The service provides COM APIs for independent software vendors to register and record the state of their products to the Security Center service. The Action Center (AC) UI uses the service to provide systray alerts and a graphical view of the security health states in the AC control panel. Network Access Protection (NAP) uses the service to report the security health states of clients to the NAP Network Policy Server to make network quarantine decisions. The service also has a public API that allows external consumers to programmatically retrieve the aggregated security health state of the system. Automatic (Delayed Start) Local Service
Server Supports file, print, and named-pipe sharing over the network for this computer. If this service is stopped, these functions will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start. Automatic Local System
Shell Hardware Detection Provides notifications for AutoPlay hardware events. Automatic Local System
Smart Card Manages access to smart cards read by this computer. If this service is stopped, this computer will be unable to read smart cards. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local Service
Smart Card Removal Policy Allows the system to be configured to lock the user desktop upon smart card removal. Manual Local System
SMS Agent Host Provides change and configuration services for computer management systems. Automatic Local System
SMS Task Sequence Agent SMS client agent for task sequence execution Manual Local System
SNMP Trap Receives trap messages generated by local or remote Simple Network Management Protocol (SNMP) agents and forwards the messages to SNMP management programs running on this computer. If this service is stopped, SNMP-based programs on this computer will not receive SNMP trap messages. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local Service
Software Protection Enables the download, installation and enforcement of digital licenses for Windows and Windows applications. If the service is disabled, the operating system and licensed applications may run in a notification mode. It is strongly recommended that you not disable the Software Protection service. Automatic (Delayed Start) Network Service
SPP Notification Service Provides Software Licensing activation and notification Manual Local Service
SSDP Discovery Discovers networked devices and services that use the SSDP discovery protocol, such as UPnP devices. Also announces SSDP devices and services running on the local computer. If this service is stopped, SSDP-based devices will not be discovered. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local Service
Storage Service Enforces group policy for storage devices Manual Local System
Superfetch Maintains and improves system performance over time. Automatic Local System
System Event Notification Service Monitors system events and notifies subscribers to COM+ Event System of these events. Automatic Local System
Tablet PC Input Service Enables Tablet PC pen and ink functionality Manual Local System
Task Scheduler Enables a user to configure and schedule automated tasks on this computer. The service also hosts multiple Windows system-critical tasks. If this service is stopped or disabled, these tasks will not be run at their scheduled times. If this service is disabled, any services that explicitly depend on it will fail to start. Automatic Local System
TCP/IP NetBIOS Helper Provides support for the NetBIOS over TCP/IP (NetBT) service and NetBIOS name resolution for clients on the network, therefore enabling users to share files, print, and log on to the network. If this service is stopped, these functions might be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start. Started Automatic Local Service
Telephony Provides Telephony API (TAPI) support for programs that control telephony devices on the local computer and, through the LAN, on servers that are also running the service. Manual Network Service
Themes Provides user experience theme management. Automatic Local System
Thread Ordering Server Provides ordered execution for a group of threads within a specific period of time. Manual Local Service
TPM Base Services Enables access to the Trusted Platform Module (TPM), which provides hardware-based cryptographic services to system components and applications. If this service is stopped or disabled, applications will be unable to use keys protected by the TPM. Manual Local Service
UPnP Device Host Allows UPnP devices to be hosted on this computer. If this service is stopped, any hosted UPnP devices will stop functioning and no additional hosted devices can be added. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local Service
User Profile Service This service is responsible for loading and unloading user profiles. If this service is stopped or disabled, users will no longer be able to successfully logon or logoff, applications may have problems getting to users' data, and components registered to receive profile event notifications will not receive them. Started Automatic Local System
Virtual Disk Provides management services for disks, volumes, file systems, and storage arrays. Manual Local System
Volume Shadow Copy Manages and implements Volume Shadow Copies used for backup and other purposes. If this service is stopped, shadow copies will be unavailable for backup and the backup may fail. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
WebClient Enables Windows-based programs to create, access, and modify Internet-based files. If this service is stopped, these functions will not be available. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local Service
Windows Audio Manages audio for Windows-based programs. If this service is stopped, audio devices and effects will not function properly. If this service is disabled, any services that explicitly depend on it will fail to start Automatic Local Service
Windows Audio Endpoint Builder Manages audio devices for the Windows Audio service. If this service is stopped, audio devices and effects will not function properly. If this service is disabled, any services that explicitly depend on it will fail to start Automatic Local System
Windows Backup Provides Windows Backup and Restore capabilities. Manual Local System
Windows Biometric Service The Windows biometric service gives client applications the ability to capture, compare, manipulate, and store biometric data without gaining direct access to any biometric hardware or samples. The service is hosted in a privileged SVCHOST process. Manual Local System
Windows CardSpace Securely enables the creation, management, and disclosure of digital identities. Manual Local System
Windows Color System The WcsPlugInService service hosts third-party Windows Color System color device model and gamut map model plug-in modules. These plug-in modules are vendor-specific extensions to the Windows Color System baseline color device and gamut map models. Stopping or disabling the WcsPlugInService service will disable this extensibility feature, and the Windows Color System will use its baseline model processing rather than the vendor's desired processing. This might result in inaccurate color rendering. Manual Local Service
Windows Connect Now - Config Registrar WCNCSVC hosts the Windows Connect Now Configuration which is Microsoft's Implementation of Wi-Fi Protected Setup (WPS) protocol. This is used to configure Wireless LAN settings for an Access Point (AP) or a Wi-Fi Device. The service is started programmatically as needed. Manual Local Service
Windows Defender Protection against spyware and potentially unwanted software Manual Local System
Windows Driver Foundation - User-mode Driver Framework Manages user-mode driver host processes. Started Automatic Local System
Windows Error Reporting Service Allows errors to be reported when programs stop working or responding and allows existing solutions to be delivered. Also allows logs to be generated for diagnostic and repair services. If this service is stopped, error reporting might not work correctly and results of diagnostic services and repairs might not be displayed. Manual Local System
Windows Event Collector This service manages persistent subscriptions to events from remote sources that support WS-Management protocol. This includes Windows Vista event logs, hardware and IPMI-enabled event sources. The service stores forwarded events in a local Event Log. If this service is stopped or disabled event subscriptions cannot be created and forwarded events cannot be accepted. Manual Network Service
Windows Event Log This service manages events and event logs. It supports logging events, querying events, subscribing to events, archiving event logs, and managing event metadata. It can display events in both XML and plain text format. Stopping this service may compromise security and reliability of the system. Started Automatic Local Service
Windows Firewall Windows Firewall helps protect your computer by preventing unauthorized users from gaining access to your computer through the Internet or a network. Started Automatic Local Service
Windows Font Cache Service Optimizes performance of applications by caching commonly used font data. Applications will start this service if it is not already running. It can be disabled, though doing so will degrade application performance. Automatic (Delayed Start) Local Service
Windows Image Acquisition (WIA) Provides image acquisition services for scanners and cameras Automatic Local Service
Windows Installer Adds, modifies, and removes applications provided as a Windows Installer (*.msi) package. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local System
Windows Live Family Safety This service enables Family Safety on the computer. If this service is not running, Family Safety will not work. Manual Local System
Windows Management Instrumentation Provides a common interface and object model to access management information about operating system, devices, applications and services. If this service is stopped, most Windows-based software will not function properly. If this service is disabled, any services that explicitly depend on it will fail to start. Started Automatic Local System
Windows Media Center Receiver Service Windows Media Center Service for TV and FM broadcast reception Manual Network Service
Windows Media Center Scheduler Service Starts and stops recording of TV programs within Windows Media Center Manual Network Service
Windows Media Player Network Sharing Service Shares Windows Media Player libraries to other networked players and media devices using Universal Plug and Play Manual Network Service
Windows Modules Installer Enables installation, modification, and removal of Windows updates and optional components. If this service is disabled, install or uninstall of Windows updates might fail for this computer. Manual Local System
Windows Presentation Foundation Font Cache 3.0.0.0 Optimizes performance of Windows Presentation Foundation (WPF) applications by caching commonly used font data. WPF applications will start this service if it is not already running. It can be disabled, though doing so will degrade the performance of WPF applications. Manual Local Service
Windows Remote Management (WS-Management) Windows Remote Management (WinRM) service implements the WS-Management protocol for remote management. WS-Management is a standard web services protocol used for remote software and hardware management. The WinRM service listens on the network for WS-Management requests and processes them. The WinRM Service needs to be configured with a listener using winrm.cmd command line tool or through Group Policy in order for it to listen over the network. The WinRM service provides access to WMI data and enables event collection. Event collection and subscription to events require that the service is running. WinRM messages use HTTP and HTTPS as transports. The WinRM service does not depend on IIS but is preconfigured to share a port with IIS on the same machine. The WinRM service reserves the /wsman URL prefix. To prevent conflicts with IIS, administrators should ensure that any websites hosted on IIS do not use the /wsman URL prefix. Automatic (Delayed Start) Network Service
Windows Search Provides content indexing, property caching, and search results for files, e-mail, and other content. Automatic (Delayed Start) Local System
Windows Time Maintains date and time synchronization on all clients and servers in the network. If this service is stopped, date and time synchronization will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start. Manual Local Service
Windows Update Enables the detection, download, and installation of updates for Windows and other programs. If this service is disabled, users of this computer will not be able to use Windows Update or its automatic updating feature, and programs will not be able to use the Windows Update Agent (WUA) API. Automatic (Delayed Start) Local System
WinHTTP Web Proxy Auto-Discovery Service WinHTTP implements the client HTTP stack and provides developers with a Win32 API and COM Automation component for sending HTTP requests and receiving responses. In addition, WinHTTP provides support for auto-discovering a proxy configuration via its implementation of the Web Proxy Auto-Discovery (WPAD) protocol. Manual Local Service
Wired AutoConfig The Wired AutoConfig (DOT3SVC) service is responsible for performing IEEE 802.1X authentication on Ethernet interfaces. If your current wired network deployment enforces 802.1X authentication, the DOT3SVC service should be configured to run for establishing Layer 2 connectivity and/or providing access to network resources. Wired networks that do not enforce 802.1X authentication are unaffected by the DOT3SVC service. Manual Local System
WLAN AutoConfig The WLANSVC service provides the logic required to configure, discover, connect to, and disconnect from a wireless local area network (WLAN) as defined by IEEE 802.11 standards. It also contains the logic to turn your computer into a software access point so that other devices or computers can connect to your computer wirelessly using a WLAN adapter that can support this. Stopping or disabling the WLANSVC service will make all WLAN adapters on your computer inaccessible from the Windows networking UI. It is strongly recommended that you have the WLANSVC service running if your computer has a WLAN adapter. Started Automatic Local System
WMI Performance Adapter Provides performance library information from Windows Management Instrumentation (WMI) providers to clients on the network. This service only runs when Performance Data Helper is activated. Manual Local System
Workstation Creates and maintains client network connections to remote servers using the SMB protocol. If this service is stopped, these connections will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start. Started Automatic Network Service
WWAN AutoConfig This service manages mobile broadband (GSM & CDMA) data card/embedded module adapters and connections by auto-configuring the networks. It is strongly recommended that this service be kept running for best user experience of mobile broadband devices. Manual Local Service
kaelanduck6 years ago
The password is stored in almost plain text on the hard drive, easily accessible, it's absolutely pointless to get hold of though as the account is disabled. Alarm bells would probably start ringing if it was enabled though
actuallly this isnt true.
the admin account may be blocked but an admin account on all the computers is under the name:
jimmy.riddle
he is the head honcho or so to speak and his account is enabled on all computers on the NSWDET network.
and no, alarm bells will not ring, the only way this could happen if the laptop connected to NSWDER prior to your logging in.
and if the account is disabled, it woud say the same thing as when you try to log in as guest. account has been disabled, contact your system administrator.
The admin' account on all the computers is not under the name jimmy.riddle. Either someone has told you that and you just believed them, or that is one name that one person gave to an account with full admin' privileges, on one system that you know.
L
i'm sorry, all the computers are on a single large domain, NSWDET. all the computers are set up so that only a handful of people are able to log in. the TSO who needs to service the netbook, the student which the laptop belongs to and the local administrator. if you try and log in as another person/student it says that you cant access it/wrong username or password.
when you try and add a new domain account, if you try and add another student or teacher to your laptop it says access denied. if you try and add yourself or the TSO or someone who can already log on it says "this person already has access to this computer", when i searched administrator accounts, i found several. most of which when i try to add to the computer it says access denied. when i try and add jimmy riddle it says this user already has access to the computer.
My TSO's name is Ankuj Narchal. a nice indian uni student. my school's regular computer guy, who i might add has no access to the computers anyway, is named Lincoln. NOONE in my school is under the name jimmy riddle so seeing as you arent even in the country i will assume that you have no prior knowledge with the NSW system of manageing the DER netbook rollout or its user system. THANKYOU VERY MUCH.
You said an admin account on all the computers is under the name:
jimmy.riddle
Therefore someone in your school has an account under that name, (not NO ONE)
I understand how the thing works better for your last comment (thanks), but as I understand it, other machines may be accessible under e.g. "j.arthur.rank", "eartha.kitt", "douglas.hurd"?
L
That's the regional network admin, I'm talking about the local administrator built-in to windows, microhard forefront can probably be setup to phone home when the account is enabled. Also you have to be connected to the domain network for the first logon if you logon as the regional admin.
I know, most other users accounts on the computers are blocked so that another student cant just log in. his account is still able to log in over the network on these netbooks meaning if someone can get his password then were in.
GonzoLives6 years ago
The only way would be to guess or find the admin's password. Many people use really bad ones or they're so obvious, it's laughable. My friend who works nights at a local company wanted to access his e-mail on break. One of the salesmen had left his computer on. He thought about the scene in "The Departed" where Matt Damon asks Leo DiCaprio his password and is told "My Name". He typed that in (without the space) and he was IN!
Other common ones are (one mag says around 20+% of employees do this) "Password"!!! Also: birthday's, significant dates, names of girlfriends, boyfriends, pets and so on.
Or, you could just hide outside the window and wait for the admin to type in the password. Ferris Bueller found the school's PW scribbled on a pull-out platform of the desk. People are idiots.
But...DON'T DO IT! You'll be grounded for life.
and BTW, nice refernece. not many people have sen FBDO, and i did do it. got my schools server pass by making careful note of how many letters the password was and guessing the rest. got suspended. FUN
1-10 of 13Next »
