loading
chargeing bateries
does anybody know how to charge a nihm battery extremely fast?
FrenchCrawler10 years ago
erckgillis10 years ago
The Ultimate Charger Sometimes the most important issue is the lifetime of the batteries or the total lifetime cost of the system. In this case a microprocessor is in a good position to offer the ultimate charger because of our wide range in microprocessor controlled battery chargers and power supplies. Specs for the ultimate charger are: 1. Soft start. If the temperature is above 40 degrees C or below zero degrees C start with a C/10 charge. If the discharged battery voltage is less than 1.0 Volts/cell start with a C/10 charge. If the discharged battery voltage is above 1.29 V/cell start with a C/10 charge. 2. Option: if the discharged battery voltage is above 1.0 Volts/cell, discharge the battery to 1.0 V/cell then proceed to rapid charge. 3. Rapid charge at 1 C until the temperature reaches 45 degrees C, or the dT/dt indicates full charge. 4. After terminating the fast charge, slow charge at C/10 for 4 hours to ensure a full charge. 5. If the voltage climbs to 1.78 V/cell without otherwise terminating, terminate. 6. If the time on fast charge exceeds 1.5 hours without otherwise terminating, terminate the fast charge. 7. If the battery never reaches a condition where the fast charge starts time out the slow charge after 15 hours.
carbon10 years ago
Yes, with a charger. And even then, you're damaging the cell a little every time.
