3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
converting a bike to a trike?
anyone have info on converting a bike to a trike? My disabled son has balance issues but wants to ride with the family, however we can't afford a new adult tricycle or one of the expensive conversion kits. He's much too large for training wheels to work. I'm hoping to find a way to convert an old bike with minimal expense and no welding.
20 comments
Jul 17, 2008. 6:17 AMTomaN says:
Valr, have you find out a cheaper solution ?. I'm in a similar condition !!!
May 7, 2012. 2:56 AMupnsmokes says:
As a hobby I build bikes and a kit you can buy on ebay is the easist solution
Mar 10, 2011. 7:31 PMdesya says:
ebay has the a conversion kit...
http://cgi.ebay.com/24-Adult-Bicycle-Bike-Tricycle-Trike-Conversion-6BK-/170613810443?pt=Cycling_Parts_Accessories&hash=item27b960250b#ht_1603wt_944
is just one I have seen
Jul 16, 2010. 6:36 PMHubiewan says:
Please contact me. I may be of some help.
Mar 23, 2009. 7:15 PMghostrider1 says:
check internet theres always plan there you must have scrap bics around and somebody with welder
Aug 9, 2008. 6:45 PMaguanile says:
The system bump me out after i wrote a lot of helpful info,but if you serious above it send me a message.I got a lot of info to share,because i am working on similar project and took some research to do. Parts, diagrams etc.
Jul 5, 2008. 3:25 AMRishnai says:
Have you seen dirt bike "training wheels"? They're the most rediculous thing I've ever seen for learning to ride a motorcycle the right way, but they'd be beefy enough to work on your son's bicycle. And it would ba a bolt-on deal, but I'm not sure about how much they cost. I wouldn't be suprised if parents of little budding dirtbikers want to get rid of some cheap, though.
Jul 3, 2008. 12:28 PMkishida says:
Adding a 2nd wheel to the front will cause steering difficulties, unless the 2 wheels articulate like a car's front wheels (each steering independently and in parallel). Training wheels or training wheels that are beefed up might be an easier and safer solution.
May 12, 2008. 1:17 PMcoatesy900 says:
The sensible person would buy some STABILISERS. They are hardly expensive, and easy to fit so you don't have to do any hard work. Seems pretty obvious to me...
May 12, 2008. 1:18 PMkillerjackalope says:
Most stabilisers are very flimsy and also not very well made, one corner too quick and they snap...
May 2, 2008. 5:24 PMkillerjackalope says:
If you need a hand figuring out give me a shout, depending on his balance problems you could have wheels twinned directly together in widened forks, obivously just spitballing but I'd say a trike that's closer to a bike would help with his balance issues a great deal...
Mar 29, 2008. 12:16 AMkillerjackalope says:
Either way it wouldn't be too hard, the front one would probably be better all round it would give insane steering capabilities and alot of fun, especially if you have suspension forks, if not back suspension, one or the other, because I'd say the trike might be a bit bumpier than a bike.
Mar 28, 2008. 8:00 PMWeissensteinburg says:
Seems like you should be able to bolt on a piece of bent steel with a wheel on the edge to the existing wheel.
Mar 28, 2008. 7:58 PMjtobako says:
The 'no welding' makes it difficult, but it depends on what you are up to. You might want to think about two wheels in the front with a single driving wheel in the back. Two additional forks in the front with a steering link to the original fork could work, finding forks that have the bolt-hole for a front brake would make the steering link easier to create. Do you just need an idea or something closer to step-by-step instructions?
Mar 27, 2008. 8:07 AMsugg22 says:
try one of the easy recumbent bike mods on this site, and then add a 3rd and 4th wheel in the back for stability.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
