eXistenZ Game Pod build.
Ok, one of my idea for a current project is to recreate my own model/version of the game pod out of the David Cronenberg film eXistenZ.
If your unfamilar, see the pics and video - Essentially the 'game pod' is a biological virtual reality games console. And i must say i am a fan of the film.
Now, i need some help, both with ideas, and with build methods.
Ideas
- I require an idea as the the use of the device - eg, an external hdd enclosure, a wallet, what ever.
- I Have a base that im going to use, in the form of a beach stone. So the size is 125mm x 125mm
Methods
- Although i have a base 'stone' i need to sculpt a little extra, to make the nodule like bits. and genrally curve the shape a bit, what can i use? would bondo do? and whats the UK equilivent?
- I want to have a silicon like finish, like the film, i was planning liquid latex, is that a good idea? what else is there thats better?
I would appreciate any help anyone can give.
Thanks
Gmjhowe
Picture of eXistenZ Game Pod build.
1-10 of 11Next »
Yeah you'll need more experience than that i'm afraid.
gmjhowe (author)  whatsisface9 years ago
ok, well, the way i see it, im not stupid, and i can learn most things. How about a simple circuit, with an on off switch, that basically gyrates and makes a noise?
Yeah, you'll likely be better off using a motor with a cam and cam follower to gyrate and a cheap sound recording module to play back the sound.
ok, i think that will be my plan, thanks for the help!
gmjhowe (author) 9 years ago
Come on peoples! i wanna make this this weekend!
Take a trip to maplin and you can get some cool plastic that you can melt using hot water and form with your hand, I forgot the name of it. It's pretty expensive though. If I were doing it, I'd just make it interactive art with a few servo's moving an outside rubber/silicon skin, and sensors feeding back what you are doing to a uC. YMMV.
hey, wow, a very usefull answer, so could i make it using a series of servos, so that depending on which 'nipple' you flick it would do a different movment and play a sound?
Yeah but it's quite a technical challenge.
ah, not a good idea for someone whos never used a servo before? the best ive done is to solder an led into a circuit.
bump
1-10 of 11Next »
