3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
false piston: how the hell do I make that?
Hello Instructonauts, I have a bit of a problem. I need to make an object with a piston like action. This wouldn't be such a big deal if I could actually just use a piston but I can't. I need a method for creating a piston movement of a cylinder inside a tube so the device moving the piston cannot be any wider than the piston. I considered pneumatics but that would require supplies I do not have and have never worked with. Does anyone know a way to make this object?
14 comments
Apr 3, 2009. 12:46 AMgr33ko says:
or maybe attach the piston to a worm gear. as long as the piston isnt compressing anything or moving fluid you should be ok
Apr 3, 2009. 12:43 AMgr33ko says:
Have you done any research on linear actuators? This may be your solution!
Mar 4, 2009. 2:54 AMlemonie says:
Mar 4, 2009. 12:43 AMMarcos says:
Are you looking for a project idea, or do you need to build a piston like an internal combustion engine? If it's the first one, why not make a fire piston, and get a cool gadget in the process. If you don't know what they are, look 'em up. I think there is at least one instructable on how to do it. Warnining Will Robinson: it's not easy, but it will be satisfying when you succeed. Let us know what you do.
Feb 17, 2009. 10:05 PMwow-amazing says:
Maybe a mouse? Or a finger!
Dec 26, 2008. 6:10 AMGoodhart says:
Would the drive similar to what a locomotive uses to transfer energy from piston to wheels, work? In reverse of course...
Dec 26, 2008. 9:19 PMGoodhart says:
Yes, but I thought you were concentrating on the "drive" which can be "outside the wheel" like the locomotive, or two lengths of metal slats that rotate around the outside of a pin....there are several ways to drive the piston, but I am not sure they fulfill your parameters.
Dec 26, 2008. 9:24 AMchiok says:
Does it need to reciprocate or is a linear motion sufficent? Or operate automatically? A rack attached to ID of the inner tube and a pinion and motor that runs along it (forward and back motion of the motor for in and out). Or a pulley system that pulls the slide like a sash window. Does that make sense?
Dec 25, 2008. 6:50 AMGoodhart says:
Are you saying that the cam or crankshaft driving the piston can not be longer than the width of the piston?
At this Link, the Conventional method of driving a piston is demonstrated.
The Wankel engine uses a totally different drive; essentially, it works like this picture demonstrates.
A camshaft can drive smaller pistons, without having a direct connection to them. And at this link, if you scroll down, you can compare both cam and crank movements.
If I am not understanding what you are asking for, try again to help me understand.
Dec 25, 2008. 7:51 PMWeissensteinburg says:
Could you just tell us what you're making?
Dec 25, 2008. 3:43 PMNachoMahma says:
. Rack and pinion?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
