loading
hard drive spindle motor?
I have a hard drive spindle motor that i have taken off of my old 10 gb Hard drive. I was wondering if i would be able to run this motor off of a pc molex connector. i have extended the wire from the molex plug and touched them to the leads on the motor, but all it does is jerk. I can't get it to stay spinning. Do you have to have a controller mechanism of some sort or what? I have tried the red wire and ground and the yellow wire and ground. They both don't seem to work. Would make a difference if i solder the wire onto the motor? I was just thinking this would make a great fan or something along that order.
1-10 of 18Next »
ddaigle5 years ago
I've developed circuitry for driving precisely this sort of motor. You can see it on my website: http://wingzero.ath.cx/index.php?page=hard-drive-motor
Check under the heading Projects: Hard Drive Motor and other pages under that.
Hope it helps!
hubi6 years ago
you could also use this home.clear.net.nz/pages/joecolquitt/0hdd.html with Picmicro
or this grant.solarbotics.net/Circuits.htm  without microcontroller
polymorf7 years ago
Atmel has a howto on spindle controllers here
Snippet:
The generally accepted definition of a BLDC (BrushLess DC) motor is a permanent magnet motor with trapezoidal back-EMF, as opposed to the sinusoidal back-EMF found in permanent-
magnet synchronous motor. This note applies to BLDC motors with
trapezoidal back-EMF.
In every commutation step, one phase winding is connected to positive supply voltage, one phase winding is connected to negative supply voltage and one phase is floating. The back-EMF in the floating phase will result in a ìzero crossingî when it crosses the average of the positive and negative supply voltage.
The zero crossing occurs right in the middle of two commutations. At constant speed,
or slowly varying speed, the time period from one commutation to zero-crossing and
the time period from zero-crossing to the next commutation are equal. This is used as
basis for this implementation of sensorless commutation control.
cool!7 years ago
I know this is an old topic, but for anyone landing on this now... The easiest way to power the spindle motor is with the original control. Wire the motor onto the HDD board as it was normally connected. Next, connect the board to a computer power supply. The motor will spin up. If the power is not connected to a motherboard, just cross any black wire on the motherboard power connector with any black wire on the connector. This will bypass the security feature on the power supply.
HICKFARM (author) 9 years ago
I am almost sure it is a spindle motor. It is the motor that spins the platters. What would i need to power it?
Keeter HICKFARM7 years ago
Electricity, I'd bet.
it's a stepper motor
http://en.wikipedia.org/wiki/Stepper_motor
you need a stepper motor controller
Nah, it's a 3 phase brushless motor. A stepper is similar, but not quite. a stepper has many "notches" per rotation. you cycle through them a step at a time by sequentially driving contacts. A 3 phase brushless is similar in that you drive it with sequential signals, but it only has 3 "notches" per rotation, and it's intended that you not drive them until they "cog", but instead switch off power to one phase, and onto the next while it's still coasting forward. Stepper motors used to be used to control the heads in very old hard drives, mostly pre-ide drives under 40MB or so. They're also used in floppy drives. So, what you would actually need is a brushless DC motor controller.
hard drive spindle motors are peculiar, because they're three phase stepper motors. generally, if you take an ohmmeter to the pins, one pin will connect to the other three at a specific ohmmage, and then trying to measure the resistance between any two of those three will result in about twice as many ohms. the one that connects to all three at a low ohm rating is the ground, the other three are your phase 1, 2, and 3. this could probably be made using ttl logic gates and a 555 timer with relative ease.
HICKFARM (author) 8 years ago
ya that is helpful Chuck if i knew how to read that pdf. I was planning on doing this a while ago, but thanks for the heads up.
1-10 of 18Next »
