headphones for a guitar?
18
comments
Add Comment
1) plugging straight into the guitar: whether or not you have an adapter on your headphones...(1/8in to 1/4in plug) you will not get a sound out of them becuase you need electricity to make the pickups work... unless there is a pre amp?
2) casset adapter... tried it, it's WAY quiet, you get no distortion and risk detaching the cable from the adapter if you pull it too hard. you need more cable and hardware then it is worth...
3) best solution... plug the headphones into your amp... it won't hurt you i promise. you can use ipod headphones with a jack adaptor (1/8in to 1/4in) or use studio headphones that are meant to be plugged into an amp
If it's a solid-state amp, you might be OK. 600 ohm impedance or so, for an average set of headphones VS. 8 ohms or so for the speaker = a very low load. Low load (or even no load) is usually doesn't hurt SS amps.
For a tube amp, BAD. Low load is worse than too high a load. The power tubes are pumping energy into the output transformer, and if you remove the load, that reactance has nowhere to go--the transformer windings fry.
would i be able to plug the cassette amp into the guitar and then headphones into the cassette player? Hows this, if i get a cassette player and solder on a guitar lead to the two roller points? that way i could plug the headphones into the cassette player like you normally would and it had the option to play from the cassette players speaker
. You may be able to modify some of the "Altoids" amps. IIRC, they get their input from something like an iPod earphone jack, so you'll need to boost the gain.
You can use old-skwl (1/4 in plug) headphones, or buy a 1/4-to-3.5mm adapter. A cassette player would already have a 3.5mm jack. A typical guitar pedal would have a 1/4 in mono output, and a 1/4 in stereo plug might work, or you might need a mono-to-stereo adapter (easy to make.)
The advice others are giving about building a small amp from scratch is good; but I don't know your level of commitment to the project.
At least search instructables for "headphone amp" to see a few options.
wtf is ur teacher on cuz i want some... amps have a headphone jack for a reason
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
