3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
help with a chaser board
Hi all i am very very new to all of this and i am working to light up a model if you can help me i would be very great full. Ok so i want to connect Led 1 threw 5 to the 555 timer and 6and 7 to be solid on. The resistors are 1/4 W 5% 470R OHM I was told to put the resistors on the negative point of the LED for the chasers. Do i need to put some on the Solid ones? I am using 4 AA Batteries for power and that gives me 6V. All of the lights will be in a serial circuit. The chasers Led are 3mm 5.0V @ 20mA The solid Led are 3mm 3.6V @ 20MA The fun part: How do i connect it all together? I bought a Breadboard and i am trying to figure it out lol !!! Now i was told that the timer chip is to bridge the gap image 2 That i also has to connect the the bottom and top of the gap like so image 3 OK so on the breadboard the resistors go parallel? from the 555 chip image 4? And the Led goes like this for the chaser image 5 ? Any help would be great and thanks
4 comments
Feb 4, 2007. 5:50 PMwestfw says:
Note that this flashes. It doesn't "chase." To chase, IMO, you need at least three outputs that are turned on in sequence. With a 555 and no other active components, you can only do two.
Feb 4, 2007. 10:52 AMphotozz says:
OK.. I think this is the diagram you need. All the resistor values were found using this site:
"http://metku.net/index.html?sect=view&n=1&path=mods/ledcalc/index_eng#parallel"
Let me know if you need help figuring out the wiring.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
