3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
help with transistors
could someone tell me if this will succeed in keeping itself on if the button is hit once?
30 comments
Apr 19, 2007. 2:43 PMVIRON says:
This may work, simply, much like like an SCR.
May 9, 2007. 12:33 AMVIRON says:
This is tested, tweaked, and now it works. Needed 10K resistors to help it.
Apr 21, 2007. 11:05 AMVIRON says:
One is NPN, one is PNP, and I use (lots of) 2N3904 and 2N3906 which are typical small transistors about 1/2 watt. In UK the equivalents start with "BC" and in Japan, "2S", with different numbers found using a "cross-reference" book or search. If they are black plastic, and viewed from above with the flat side facing right, or from the bottom with flat facing right, the top pin is C, the middle B, and the bottom E. In schematics E has the arrow and B is straight from the middle. Various other transistors have pins in BCE or reverse order, you have to test them or look them up to know. The "diode" is an LED. I changed my idea; don't use the 1K resistor, but it might be necessary to use a 10K from there to the negative for the "off" button to work. BTW the one "transistor" circuits might work if you use an SCR or TRIAC which can be found in small lamp dimmers as the transistor. They don't "dim" DC, but they do latch on when you push a button in a DC circuit. They also handle lamps up to and over 100 watts.
Apr 19, 2007. 12:38 AMwestfw says:
Here is a pdf containing your basic two-transistor bistable circuits to implement a set/reset latch, a monostable (pulse) circuit, and an oscillator (which happens to be the same as my Instructable on PCB DRCs, although that's not specifically what it was about.)
Somewhat more complex but essentially similar circuits make up MANY a standard Integrated Circuit, from 555s to flipflops to registers and static RAM.
Apr 17, 2007. 12:29 PMLasVegas says:
Unlikely, but possible. It depends on the voltage available, the specs of the transisitor, the current of the lamp and the values of the resisitors. In other words, If this were on a test, the answer would be "Not enough information to answer."
Apr 17, 2007. 1:55 PMLasVegas says:
The following is your schematic, corrected for using an NPN transistor as a switch. Note the differences and follow the current to understand how it works. Normally, I would place power on the left. I tried to keep the layout similar to your's to allow comparison.
Apr 17, 2007. 5:15 PMLasVegas says:
Place a small capacitor between the base and collector (negative of the battery). To turn off, short the capacitor. BTW: This is actually how dynamic RAM works. Capacitor charged, is on, discharged is off. The problem is that the capacitor has to be refreshed regularly. Static (Nonvolatile) memory works by toggling a transistor switch.
Apr 17, 2007. 11:35 PMmicroman171 says:
here is a site to test them out: Circuit Simulator
I found that the capacitor does need to be recharged all the time and it defeats the purpose...
Apr 18, 2007. 2:24 PMLasVegas says:
You would need at least two transistors to create a flip-flop circuit to toggle the LED on and off.
Apr 17, 2007. 5:51 AMmicroman171 says:
it almost looks like it is always on. Im interested in this because I seem to always have to make latches outa relays... Im gunna make it and see if it worx 4 u.
Apr 17, 2007. 6:12 AMmicroman171 says:
I have no Idea... Ill hav a play tmrrw
Apr 17, 2007. 9:16 AMmexx.admin says:
what's a transistor?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
