how can i build a pump?
i need to pump water out of a hole where a cracked water line is leaking. can i build one with a fan motor? i have no pics.
kurapika9 years ago
Depends on your application.
Pump water from a shallow (less than 20ft)or deep (greater than 20ft) well?
How much volume(gpm) and pressure(psi) are you looking for?
Based on standard house current at 110VAC or off of a car battery(12V) and how long do you plan to have this pump running (few minutes at a time or hr's or day's on end)?
Your question can be simple or a major under taking.
A simple pump, using an old wash machine pump and motor you can come up with a basic pump. This will work on a shallow application, meaning the pump can't draw water from a resavoir being very deep, maybe a few feet.
A sump pump is also a very shallow well type, works from a jet principle, but can't deliver a lot of pressure 10-15psi for a short period of time.
Water wells which are deep, > 30ft, usually have the pump submerged into the water which then pushes the water out vs drawing the water up.
Some of the older pumps were of a piston design, inefficient compared todays jet pump standards.
Otherwise an electric motor and a mechanical pump.
Hope it helps.
-from furniture lover
jennakp (author)  kurapika9 years ago
Thanks for your help. It's more than I can do myself. I'll have to buy a pump. Spit! jenna
Rishnai9 years ago
Yes, in theory you can. You need a centrifugal design, like a leafblower. In fact, you could probably open up a leafblower, do a little waterproofing, and you'd be good to go. A gasoline one would just need a snorkel, while an electric one would need a little more... How big is the hole, and have you managed to shut off the water to the pipe in question?
jennakp (author)  Rishnai9 years ago
thank you so much for your reply! but i finally found someone with a pump.
Rishnai jennakp9 years ago
You're welcome. Having a big hole full of water is no fun unless you meant to put it there!
NachoMahma9 years ago
. Moved from Help:Authors to Forums:Home
