Autodesk: Make Anything
loading
how can i remove stripped screw heads?!?!?
how do i remove on with a messed up head sorry for bad pic
Picture of how can i remove stripped screw heads?!?!?
1-10 of 18Next »
If there's any grooves at all left on the screw head, place a rubber band on the end of the appropriate screw driver, and then line it up with the grooves and press down hard and turn.
Sometimes it works, but sometimes the screw head is too far gone. :)
Yeah, I usually use that way Sir!
She doesn't look like a Sir to me...
Shush man. What ever. That shows respect man!
If you have a wiener yeah...
Hey man, what is a wiener?
I'm an honorary man!
O
"O"? I guess you lost one of your marbles! It must be either oh or no or or or on or mo or go or ho..................
Read that sentence quickly everyone. Your tongue will hate you when you don't read it out loudly and quickly!!!
If the screw is not recessed in a hole, then you can grip the head with a pair of pliers or vice-grip-like locking pliers, and unscrew it that way.
Sometimes you can use a dremel-like tool for cutting a slot in the top of the screw.  Then you remove the screw by turning this slot with a flathead screwdriver.
1-10 of 18Next »
