loading
how do u get aluminium powder
how do u get aluminium powder? do u just grind aluminium into a fine powder or what??
1-10 of 72Next »
You have to find a Termite nest, then take you pick...
Why so complicated??
Just make two pieces of aluminium very angry,
lock them in an airtight container,
let them fight until it is silent in the box again,
carefully open the box and take the powder out.
Discard of too big chunks and put them back in the container for the next fight, they will get crushed...
LasVegas9 years ago
You could also break open an old Etch-A-Sketch.
IF i break open my phone with the etch-a-sketch app running, will that work??
ttoddd LasVegas9 years ago
I did and I'ts full of tiny plastic beads which are imposible to separate out of the aluminum powder beacause they are so small.
. The beads will probably float in water if they are plastic. You may have to add a wetting agent (eg, soap) to get the Al to break the surface tension and sink.
has anybody tested this out? I'd be interested in the results.
could you just mix aluminum foil and bleach together in a jar to make aluminum powder?
That's called an acid bomb, and it's very dangerous.
Which is called an acid bomb? Mixing bleach with aluminium?
1-10 of 72Next »
