loading
how to combine 2 Arduino codes together ?
Hello, I have a question. I need to combine my code for my Arduino project. I'm using a Arduino micro board .  The 2 codes are maxsonar and another is a flying drones coding. I'm lost and don't know how to combine the both of them as the maxsonar code will overwrite the flying drones code causing it unable to fly.
Maxsonar code
const int anPin1 = 0;
const int anPin2 = 1;
int triggerPin1 = 13;
long distance1, distance2, cm1 ,cm2;
void setup() {
  Serial.begin(9600);  // sets the serial port to 9600
  pinMode(triggerPin1, OUTPUT);
  pinMode(A5, OUTPUT);
  pinMode(A11, OUTPUT);
void start_sensor(){
  digitalWrite(triggerPin1,HIGH);
  delay(1);
  digitalWrite(triggerPin1,LOW);
void Fading()//led1
if (distance1 == 9)
   analogWrite(A5,25.5);
    delay(10);
else if (distance1 == 8)
   analogWrite(A5,76.5);
    delay(10);
else if( distance1 == 7)
   analogWrite(A5,153);
    delay(10);
else if(distance1 == 6)
   analogWrite(A5,255);
    delay(10);
  void Fading2()//led1
  if (distance2 == 9)
   analogWrite(A11,25.5);
    delay(10);
else if (distance2 == 8)
   analogWrite(A11,76.5);
    delay(10);
else if( distance2 == 7)
   analogWrite(A11,153);
    delay(10);
else if(distance2 == 6 )
   analogWrite(A11,255);
    delay(10);
void read_sensors(){
  Scale factor is (Vcc/512) per inch. A 5V supply yields ~9.8mV/in
  Arduino analog pin goes from 0 to 1024, so the value has to be divided by 2 to get the actual inches
  distance1 = analogRead(anPin1)/2;
  distance2 = analogRead(anPin2)/2;
void count_in_cm()
  cm1 = distance1 * 2.54;
  cm2 = distance2 * 2.54;
void print_all()
  if( distance1 <10 && distance2 >=10 )
  Fading();
  analogWrite(A11,0);
  Serial.print("Sensor1: Warning");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print("S2");
  Serial.print(" ");
  Serial.print(distance2);
  Serial.print("in");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(cm2);
  Serial.print("cm");
  Serial.println();
  delay(700);
  else if(distance1 >= 10 && distance2 < 10)
  Fading2();
  analogWrite(A5,0);
  Serial.print("S1");
  Serial.print(" ");
  Serial.print(distance1);
  Serial.print("in");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(cm1);
  Serial.print("cm");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print("Sensor2: Warning");
  Serial.println();
  delay(700);
  else if (distance1 < 10 && distance2 < 10)
    Fading();
    Fading2();
    Serial.print("  ");
    Serial.println();
    delay(700);
  else
  analogWrite(A11,0);
  analogWrite(A5,0);
  Serial.print("S1");
  Serial.print(" ");
  Serial.print("in");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(cm1);
  Serial.print("cm");
  Serial.print(" ");
  Serial.print(" ");
   Serial.print("S2");
  Serial.print(" ");
  Serial.print("in");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(cm2);
  Serial.print("cm");
  Serial.println();
  delay(700);
void loop() {
  start_sensor();
  read_sensors();
  count_in_cm();
  print_all();
  delay(200); //This is the equivant of the amount of sensors times 50.  If you changed this to 5 sensors the delay would be 250.
flying drone code
#include <Servo.h>
#include <string.h>
// channel declaration
Servo channel1; // throttle
Servo channel2; // yaw
Servo channel3; // pitch
Servo channel4; // roll
Servo channel5; // ball drop servo
// PWM freq setting, should it be 62.33Hz?
const int PWMConst = 20022;//50HZ
// global variables
byte incomingByte, incomingByteUSB;
byte rcBuffer[32], usbBuffer[12];
int i = 0, j = 0, STATE = 1;
int Flag = 0, usbFlag = 0;
unsigned int thr_16int = 0, yaw_16int = 0, pit_16int = 0, rol_16int = 0, gear_16int = 0;
unsigned int thr_16int_usb = 0, yaw_16int_usb = 0, pit_16int_usb = 0, rol_16int_usb = 0;
float throttle = 1000, roll = 1500, pitch = 1500, yaw = 1500;
int gear = 1500;
float currT, prevT = 0, _flagHover, throFlag;
// functions declaration
void extract_RC_cmd(void);
void extract_USB_cmd(void);
void translate_RC_cmd(void);
void translate_USB_cmd(void);
void RC_Neutral(void);
void reset_usb(void);
void reset_rc(void);
void hover(void);
void sonar(void);
void setup()
  // setting registers
  TCCR1A = _BV(COM1A1) | _BV(COM1B1);
  TCCR1B = _BV(WGM13) | _BV(CS11);
  ICR1 = PWMConst;
  // set PWM I/O ports
  channel1.attach(6);    // throttle
  channel2.attach(9);    // yaw
  channel3.attach(5);    // pitch
  channel4.attach(10);    // roll
  channel5.attach(11);   // fail safe-attit
  //init usb buffer
  usbBuffer[0] = 0x03;
  usbBuffer[1] = 0xE8;
  usbBuffer[2] = 0x0D;
  usbBuffer[3] = 0xAC;
  usbBuffer[4] = 0x15;
  usbBuffer[5] = 0x7C;
  usbBuffer[6] = 0x1D;
  usbBuffer[7] = 0x4C;
  reset_rc();
  reset_usb();
  Serial1.begin(115200);   // rc Rx data in
  Serial.begin(115200);     // USB
void loop()
  // accept serial data from computer
  if (Serial.available() > 0)
    incomingByteUSB = Serial.read();
    if (incomingByteUSB >= 0x03 && incomingByteUSB <= 0x07)
      usbFlag = 1;
    if (usbFlag == 1)
      usbBuffer[j] = incomingByteUSB;
      j++;
      if (j == 12)
        usbFlag = 0;
        j = 0;
        extract_USB_cmd();
  // accepte serial data from RC
  if (Serial1.available() > 0)
    incomingByte = Serial1.read();
    if (incomingByte >= 0x80 && incomingByte <= 0x87)
      Flag = 1;
    if (Flag == 1)
      rcBuffer[i] = incomingByte;
      i++;
      if (i == 32)
        Flag = 0;
        i = 0;
        extract_RC_cmd();
    // Serial.print(rcBuffer[i]);
  // STATE MACHINE
  switch (STATE)
    case 1:
      translate_USB_cmd();
      reset_rc();
      //Serial.print();
      break;
    case 2:
      translate_RC_cmd();
      reset_usb();
      //Serial.print('R');
      break;
    case 3:
      landing();
      break;
    default:
      RC_Neutral();
      break;
  // output PWM
  channel1.write(throttle);
  channel2.write(yaw);
  channel3.write(pitch);
  channel4.write(roll);
  channel5.write(gear);
// local functions
void extract_RC_cmd()
  if (rcBuffer[0] >= 0x80 && rcBuffer[0] <= 0x87) // double check throttle range
    thr_16int = rcBuffer[0] << 8 | rcBuffer[1]; // 16 bit throttle
    // Serial.print(thr_16int);
  if (rcBuffer[4] >= 0x19 && rcBuffer[4] <= 0x1E) // double check yaw range
    yaw_16int = rcBuffer[4] << 8 | rcBuffer[5]; // 16 bit yaw
    //Serial.print(yaw_16int);
  if (rcBuffer[16] >= 0x09 && rcBuffer[16] <= 0x0E) // double check yaw range
    rol_16int = rcBuffer[16] << 8 | rcBuffer[17]; // 16 bit yaw
    //Serial.print(rol_16int);
  if (rcBuffer[20] >= 0x11 && rcBuffer[20] <= 0x16) // double check yaw range
    pit_16int = rcBuffer[20] << 8 | rcBuffer[21]; // 16 bit yaw
    //Serial.print(pit_16int);
  if (rcBuffer[22] >= 0x21 && rcBuffer[22] <= 0x26) // double check gear range
    gear_16int = rcBuffer[22] << 8 | rcBuffer[23]; // 16 bit pitch
  // state
  if (rcBuffer[24] == 0x37 && rcBuffer[25] == 0xE0)    // Fmode SW state 1: Auto
    STATE = 1;
  else if (rcBuffer[24] == 0x34 && rcBuffer[25] == 0x00) // Fmode SW state 2: Manual
    STATE = 2;
  else if (rcBuffer[24] == 0x31 && rcBuffer[25] == 0xB4) // Fmode SW state 3: Emergency landing
    STATE = 3;
  if (usbBuffer[0] >= 0x03 && usbBuffer[0] <= 0x07) // double check throttle range
    thr_16int_usb = usbBuffer[0] << 8 | usbBuffer[1]; // 16 bit throttle
  if (usbBuffer[2] >= 0x0B && usbBuffer[2] <= 0x0F) // double check yaw range
    yaw_16int_usb = usbBuffer[2] << 8 | usbBuffer[3]; // 16 bit yaw
  if (usbBuffer[4] >= 0x13 && usbBuffer[4] <= 0x17) // double check pit range
    pit_16int_usb = usbBuffer[4] << 8 | usbBuffer[5]; // 16 bit pitch
  if (usbBuffer[6] >= 0x1B && usbBuffer[6] <= 0x1F) // double check rol range
    rol_16int_usb = usbBuffer[6] << 8 | usbBuffer[7]; // 16 bit role
  // state
  if (usbBuffer[10] == 0x2A && usbBuffer[11] == 0xF8)
    //state = 1; // auto
  else if (usbBuffer[10] == 0x2C && usbBuffer[11] == 0xEC)
    STATE = 3; // emergency landing
  else if (usbBuffer[10] == 0x2E && usbBuffer[11] == 0xE0)
    STATE = 0; // default rc neutral
  throttle = (thr_16int - 30752 ) / 2.016;
  yaw   = (9243 - yaw_16int) / 1.382;
  pitch = (pit_16int - 3047) / 1.378;
  roll  = (5129 - rol_16int) / 1.373;
  gear  = (gear_16int - 7506) / 1.165;
  throttle = min(2000, max(1000, throttle));
  yaw      = min(2000, max(1000, yaw));
  pitch    = min(2000, max(1000, pitch));
  roll     = min(2000, max(1000, roll));
  gear     = min(2000, max(1000, gear));
  throttle = thr_16int_usb;
  yaw = yaw_16int_usb - 2000;
  pitch = pit_16int_usb - 4000;
  roll =  rol_16int_usb - 6000;
  //Serial.print(thr_16int_usb);
  throttle = 1000;
  yaw = 1500;
  pitch = 1500;
  roll = 1500;
void landing(void)
  throttle = throttle - 1;
  if (throttle <= 1000) throttle = 1000;
  yaw = 1500;
  pitch = 1500;
  roll = 1500;
  thr_16int_usb = 1000;
  yaw_16int_usb = 3500;
  pit_16int_usb = 5500;
  rol_16int_usb = 7500;
void reset_rc(void)
  thr_16int = 0x8000;
  yaw_16int = 0x1C03;
  pit_16int = 0x13FD;
  rol_16int = 0x0C07;
It might be a little more complicated than that. You have to understand what the flight control program is doing, especially when it is waiting for a command and then executing it. You then have to figure out the best place to perform your function of letting the sensor calibrate/sense and then light up the leds. With the delay of that, your drone could be out of control if not timed right.
+1
Full understanding of how each sketch works is needed if your going to stitch them together into a single sketch. It can get rather complicated.
