15
comments
Add Comment
sort by:
active |
newest |
oldest
Nov 21, 2010. 3:23 AMblobatron
says:
this may sound weard but if you have a plastic slege or a inner chube if you spray hedrin anthead lice the swide affect is that it makes it stupidly fast im sceroius! >:)
Just out of interest, how do you find something like that out????
I mean it’s not like spraying head lice cure on an inner tube is something we all do every day is it?
Were you just trying random sprays as lubricants or was it a carefully planned scientific process to discover the best one you could?
Contact surface design:
Modern snow skis have a variety of shapes for different snow. Wide for powder, etc.
Try to trim the contact area to the most efficient: load bearing yet min surface area (drag).
Dec 4, 2010. 4:11 AMspenfisher12
says:
wax wax oh and did i say wax yet also reduce wind resistance as much as possable
Jan 15, 2009. 4:47 AM11010010110
says:
pass electriciyt thru them to make em hot (as =SMART= said)
Jan 15, 2009. 4:33 AMMaxSpeed
says:
There's always the obvious, point it downhill, but aligning the skis usually helps
If it has runners, waxing them can do the trick, especially in very wet semi-freezing snow. Even candle wax can help some (rubbed on, no need to melt it).
. Yep. Wax is the way to go. Candle wax works, but the wax composition is highly variable - might take some experimentation to find the right candle - and tend to flake off when cold. Car wax works well (I used Maguire's when I lived in N IL). I've never tried it, but I've heard that snow ski wax works very well. . Oh! And polish the runners before waxing.
Yeah I am sure Ski or snow board wax would be best, but in the absence of either of them, the automobile wax should hold up the best.
wouldn't margarine tend to get wiped off the blades after one run? It might make if fast for one trip though, if that is all that is needed :-)
Dec 30, 2008. 4:38 PMChicken2209
says:
My Foundations of Tech teacher said that running wax paper along the runners should do the trick ;D
Yes, that should help, if not for the long run, at least for a few.
wax the runners like goodhart said, if there metal heat them up and that might work
Roger Boisjoly dies at 73; engineer tried to halt Challenger launch
Follow up on the Arduino Jam Belgium
I need some help with paper mache angry birds for a party game
A new shirt
Wanna know what I'm doing with the laser cutter?
What would you make with a desktop CNC milling machine
Arduino Jam Belgium
December beard-off!
