iRobot Scholarship idea : Pool Cleaner
Pool Skimmer.avi1 MB101
comments
Add Comment
| 1-100 of 101 | next » |
_
X---|---o|o----|---X
If that stays how it should...then the X's are water wheels, the -'s are axels, the o's are bearings. The robot will be places on top, so each wheel will power one propeller. The bearings will be used to keep the axels in place. Bushings will help keep the axles water tight...but I need help finding rubber bushings...does anyone know where to look? I'm using 1/2" pipe as the axle, which needs to fit through the bushing. Also, i'm seeing measurments on bearings such as 5x11..what does that mean?
Thanks =]
. I'll talk to my friend and see about getting y'all together. I do remember him mentioning a web site called Scream and Fly. Just checked and sure enough, http://www.screamandfly.com/ is a site for "hot rod" boaters - try posting to one of the forums. They may even be able to tell you how to guesstimate. LOL
Oh btw here is a video of a underwater robot I built for a conference. (the first one). Its made from Lego Bricks and a programmable controller.
http://www.youtube.com/watch?v=J5ndxtPJ6Bw
. Weissensteinburg, if anything I say contradicts cooblades, I think you know who to listen to - I'm not even in the same league (maybe not even the same game).
. It will need some type of thrust bearings to keep the magnets apart. The bearing mounts will need to be sturdy, which may present space or aesthetic problems. For your use, plastic/plastic or plastic/steel may work, which would make them easier to fabricate, ie, no "real" bearings, just pick low-friction materials.
. Alignment may present problems.
. The distance between the magnets (hull + 2 airspaces) may require larger and/or more expensive magnets that don't fit your space or budget.
. These may not be a problem for you, but I think you need to do some experimenting before you get too far with your design.
. While I think the Cool Factor of a magnetic coupling is orders of magnitude greater than cooblade's grease seal, the grease seal should be much more practical. Very easy to seal the hole in the hull and it shouldn't be too hard to find a "grease" that won't leave a slick.
. I'm not trying to talk you out of it - I think you can do it - just that I'd run some proof-of-concept tests before trying to design around it. It's shape/config may change drasticly before you nail it down. Maybe hold a couple of good disc magnets about 1/4" apart and see if it feels like enough torque can be transmitted.
. Great idea! That should float long enough for testing and the price is right. A good coat of paint/varnish/wax/etc and it might float for days (and would probably make it more rigid, ie, more like plexiglas, also).
> *really hopes to win*
. Your's is the most practical idea I've seen.
. The thiefbot comes close. Very high Cool Factor (especially with the right appearance and sound effects), but finding/acquiring random objects may be difficult to implement even if he's not picky about what gets picked up.
However I think you are confused with what I was talking about earlier. Here is a link to clear things up
http://www.owenscorning.com/around/insulation/products/insulpink.asp
These boards are NOT fiber glass. They are Polystyrene and pretty safe to use for hobby work such as this. Here is a link of someone who used this to make a game icon. You can carve very nice models using a Hot Wire Knife
http://oz.games-workshop.com/games/40k/daemonhunters/terrain/icon/default.htm
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=BGF
If it were up to me I would just take apart the irobot and rip the connections off the motor and use a external motor to power the boat. It costs more but its easier. However your pipe idea is very novel, I would love to see a video if it works.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
