knex ideas page
Alot of people have asked what they should post, so now there is a forum for it
1-10 of 28Next »
D.D. Master8 years ago
Heres an idea, a removable mag for oodamo bullets.
Done a few months ago.
TheDunkis9 years ago
ok i got some badly drawn sketches in paint so you hopefully understand what i ment a little better...at least a little. first image-Top veiw of the gun facing north. second- side view facing west with trigger not pulled third- same side view but with trigger pulled
sillydude123 (author)  TheDunkis9 years ago
you are a genius! this is an amazing machanism. I finally undersand! However there will be an issue with friction, but this can be overcome with elastic bands pulling the bullets into place instead of them 'falling'
yeah i just thought off that too...also it would help the bullet and the rubber bands stay on the same level because well the rubber bands grip everything together so that they move at the same time there is still a small chance that something falls first and the rubber band pops off and jams the gun. I thought this was a fairly simple concept and i was going to enter it in the contest killerk was going to start but i never got around to it...also it would be a pain to reload
Well I suppose you could make it into a removable magazine then it might be easier to reload.
yeah but would would have to do that as in the way it's set up wouldn't allow it otherwise. it would still be hard to make it easy enough to reload...the best i could do would probably be like a 20 second reload at the fastest (i'm also trying to come up with a gun and magezine that loads really fast as in you can pop it on and off very easily and it will be fixed to autoload without usng gravity as these often jam)
I tried your original design and it dosent work, the rod that holds the ammo bends because it is only being held in one place, but nice idea.
oh i forgot to mention that all the rods are supposed to be connected at the top. (or bottom if you decided to do it that way) this should keep its sturdy enough.
i tried it at the top but it didnt work
1-10 of 28Next »
