make your own breadboard?
is there a way to make your own breadboard? could you get 2 pieces of thin balsa, drill appropriate holes insert a layer if tinfoil between them? how do you do it???(if there is even a way) thanks for any help i receive regarding this topic
egammoc7 years ago
what about a small drill bit, a dremel to use it, and glue lie 4 pieces of card stock together? would that work?
VIRON9 years ago
I have made really small solderless breadboards out of the connectors on a bunch of old IDE hard drive cables. Not my preference though. The connectors must be disassembled off the cables and glued and rewired together... worthwhile if you are in need AND you just happen to have a pile of old ribbon cables.
ledzep567 (author) 9 years ago
oh...
Brennn109 years ago
It would probably cost more, and be harder to make one. They are not very expensive, so your best bet would be to purchase one. (Like Guy and Goodhart have said)
Here is a simple one however, although I think they may be joking a bit: Homemade Bread board
Goodhart9 years ago
Here is one method, for instance: Breadboarding Socket
Goodhart9 years ago
Well, I didn't "make" them, I simply wired (and bracketed) a few together to get bigger breadboards, or soldered a ground strip or a permanent socket put in place etc. Some of the cheaper boards are not easily gotten into though.
Goodhart9 years ago
I would have to agree with Guy up to a point. I have made breadboards "better", but I still bought them (then either made connections between a few of them or added perm LED indicators etc.) Modding them is cool too :-)
guyfrom7up9 years ago
I know it's goes against the site, but it's easier just to buy one. It requires a bunch of pins, using your idea you might not get proper connections.
