loading
math fromula
thought this would be an appropriate place to share some of what i thought was interesting information to do with the area of a triangle and how numbers co-relate.
To round off a square to 100cm square, one quarter of that area is 25cm square, (10cmx10cm =100/(div)25%=25cm), the area of a  right angle triangle with sides measuring ~7.0710cm,  equals ~25% of 100cm square,  25cm square of area,  (7.0710/2=3.5355 x7.0710=24.9995205).
7.5937 if it is an equilateral triangle.
it is a standard size i use,  a handy measurement if you use templates for construction because it in  some way represents a metric increment,
thanks,
Kim
(the formula i used is half the base times the height,  unless im mistaken i recall that is the correct formula?  though i am not a full time mathamatician.  for the equalateral triangle i used a web based polygon area calculator.)
Picture of math fromula
lemonie4 years ago
There was a Greek Guy called Pythagoras who figured-out triangles about 2500 years ago.
L
And IIRC, someone did so even earlier....although few records of it exist.
Egyptian engineers certainly used the "3-4-5" relationship to make carpenter's squares. The Babylonians also knew (the "Plimpton 322" tablet) of the general relationship.
QSDR (author)  kelseymh4 years ago
i saw a doco on egyptian building they showed a variation of a water level,
The device is calibrated by the base point(s) located on the surface of water and the position of the string is marked, (probably with a scribe back in the day). perhaps a stonemasons level.
I thought I remembered something along those lines from high school courses many decades ago (about 4 actually) ;-)
kelseymh4 years ago
All you've done is to cut your square along the diagonals. Each of the resulting quarters is obviously a right triangle, with hypotenuse equal to the side of the square, and sides both equal to 1/sqrt(2) times the hypotenuse.
It's a pity you just copied the output of some Web-based calculator, rather than learning the underlying geometrical relationships involved.
You're so spiteful sometimes... that made me laugh, I'm still smiling.
L
AKA the 1:1:root(2) triangle.
