measuring petrol/ethonol accurately
G'day All,
If this has been done before, I apologise, but I have not found anything when I have searched.
I am a team manager for a team of students who need to design, construct a three wheeled vehicle. The test is a 24 hour "trial" (more like a race ;-) )
We have been competing in a category for "Hybrid Vehicles" which an additional power source to asssist the rider. In our case it is a 50cc engine using a friction drive arrangement so we can disengage it if required or if we desire. The reason for this is that we only recieve 3 litres of petrol for the event............ This is my problem. I have not been able to measure petrol in the tank accurately enough. Over the last two years I have had one litre left or ran out after 21 hours.
I have been thinking of using a strain gauge or load cell to measure the weight of the tank. I'm thinking it could be as simple as powering up the load cell with the appropriate voltage, and measuring voltage drop across it, maybe with an added resistor. Or it could be made more complex by using a circuit to drive a number of LED's giving an indication of the fuel in the tank.
If anyone outhere has any ideas to do this simply and reliably, I would love to hear from you. If it is more complex then so be it.
Here is a link to the event to give you an idea of what it is about
http://racvenergybreakthrough.net
New Instructables Books for 2013
Souped Up: Projects to Make Everything Better [Book]
Backyard Rockets Book on Sale Now
Awesome Discounts for Pro Members
JUNE 2013 Build Night - 3D Printing with 123D & Tinkercad
Instructables Build Night w/ Bare Conductive @ Noisebridge
Embed a 3D viewer in your Instructable
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Visit Our Store »
Go Pro Today »
With three or four lines sequentially lower you'd have a rough idea of your rate of fuel usage and how much fuel was left. More low-tech than previous suggestions but it would be relatively inexpensive and fairly robust.
Otherwise you should be able to mark-off on glass bottles to 3L
L
You might have a go at seeing whether you can measure depth accurately with a light-source & light-sensitive receiver, but I wouldn't.
If the tilt of the pit-lane is putting the tank-reading-out, you could make a device to measure the angle and construct a chart by degrees to adjust the reading.
L
I said currently as the rules are changing to force us to use an ethonol blended fuel (85% ethonol) so the tank may change to suit, depending on the rules next year.
I'm after something where I can be close to 100% certain on the amount of fuel left. So I can determine how hard we can go.
- to have two sight glasses, one on each side of the tank, and average the readings
- get the pit crew to construct a level area- a sheet of plywood, shimmed under the corners until it's level in both axes (or even just one if both is too hard) should do
I am assuming that you could get a ranging sensor to not explode the gas. :)
L
